Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > What's leaking now
      09-24-2020, 08:59 PM   #1
andrewsmith335i
24
Drives: 2015 BMW X3, 2009 BMW M3
I have noticed a small oil leak from the back of my engine. I'll attach pics. For what it's worth, I just had turbos, oil pan gasket, valve cover gasket, ofhg done recently. It looks like one of the drain lines for the turbos but I'm not a mechanic and I'm probably wrong. I noticed what seems to be some oil around cylinder 6, possibly pcv? Anything helps, thanks.
      09-24-2020, 09:20 PM   #2
relative4
Drives: '08 335xi E90 MT stage 1+
Eeh, could be rear main. I'd have whoever did the turbos peep it.
      09-24-2020, 10:11 PM   #3
andrewsmith335i
24
Yeah, the thing is when I had most of that work done I had the whole car inspected and they said it was 100%. I don't think the rear main would get to the point that it's leaking on the floor in the span of 4 or so days. That's why I think it might be a drain line.
      09-24-2020, 10:18 PM   #4
Mustafa.e92
Mustafa.e92's Avatar
206
Drives: 2009 bmw 335i
For what it's worth after I had all the crazy leaks fixed. Engine kept puking oil had me going crazy wondering what was still leaking. 2 weeks after no more oil dripping. Could be excess oil build up from before doing the jobs.
      09-24-2020, 10:31 PM   #5
andrewsmith335i
24
I'll give it some time, I sure as hell hope that's the case
Would make some sense considering my oil pan gasket was practically non existent, this is in that area
      09-24-2020, 10:33 PM   #6
Mustafa.e92
206
For me it was the ofhg. Everyday the alternator would empty out its reservoir of junked oil
      09-24-2020, 10:34 PM   #7
andrewsmith335i
24
Same area? Right behind oil pan?
      09-24-2020, 10:37 PM   #8
Mustafa.e92
206
Mostly around the front of the engine. But ofhg oil leaks down the front and down the oil pan to that area. I mean if they didn't clean out the front of your block it could be residual oil leaking down. Is their oil on ur valve cover hard to see in pic
      09-24-2020, 10:38 PM   #9
Mustafa.e92
206
Also if your ofhg was leaking bad inspect ur serp belt
      09-24-2020, 10:47 PM   #10
andrewsmith335i
24
It was, I just pulled a belt out of the oil pan and timing chain...part of the reason I got a 6MT e92 for peanuts. I inspected my belt tonight and it's nice and dry, valve cover gasket was done recently too.
