BMW M5 F90 (2018+) General Forums Wheels | Tires | Suspension | Brakes | Chassis    305/35r20 Rear 285/35r20 Front
      09-21-2020, 02:31 PM   #1
siba32
Drives: F10 530d 2011 245/540
2018 BMW M5 F90  [0.00]
Anyone Running this setup?
Im currently facing wheel spin on Stage 2 with Michelin PS4S. Is it safe?
      09-21-2020, 02:41 PM   #2
Used2be
Perennial PFC
Used2be's Avatar
Drives: F90 M5 DG/Aragon
Size wise you should be fine with regard to the transfer case. I'm running 305/30 20 rear with 285/30 20 front. I want to go to a 295/30 front, so I'm interested in the clearance situation too. I'm stock, but try Michelin SC2 tires, no slip for me.
      09-23-2020, 07:01 AM   #3
Higgs Boson
In the Details
1810
Drives: Yes
2020 AMG GTR  [0.00]
2022 R8 Quattro Spyder  [0.00]
2023 X5M50  [0.00]
2023 718 Spyder  [0.00]
2024 Silverado  [0.00]
2024 Civic Type R  [0.00]
305/295 here
      09-23-2020, 08:13 AM   #4
Used2be
Perennial PFC
Used2be's Avatar
Originally Posted by Higgs Boson View Post
305/295 here
I assume that's 305/30 and 295/30? Are you running Michelin SC2 also? No rubbing on the plastic at full lock in front? I'm lowered slightly, is your car also? Oh, just remembered I'm on a 10" wide front rim, but that probably doesn't make any difference. What's your front rim width?
      09-23-2020, 08:39 AM   #5
GTATX
GTATX's Avatar
Drives: 2020 M8 Comp First Edition
I'm running this without any issue. U can't run spacers in the rear with this that for sure.
GT
2020 BMW M8 Comp First Edition
2019 Panamera Turbo
2021 BMW X6M Comp
2019 BMW M5
2018 Maserati Ghibli SQ4 GranSport
      09-24-2020, 12:44 AM   #6
Jonathan G.
Drives: CLS55 AMG , Audi S6 Presige, F
305/295 here
305/295 here
Are these 295/35-20 in front and 305/35-20 in rear?
With what wheels and what are their offsets ?
Are you at stock ride height or lowered ?
No rubbing at all in the front turning from lock to lock?
Thanks!
      09-24-2020, 06:48 AM   #7
Higgs Boson
In the Details
1810
Drives: Yes
2020 AMG GTR  [0.00]
2023 X5M50  [0.00]
Thanks!
Lowered on Eibach Springs
Michelin PS4
295/35/20
305/35/20
Wheels are the Titan7
20x11 +22
20x12 +30
Front pushes out 16mm vs stock
Rear pushes out 8mm vs stock
The only time I sense a rub is backing out of my garage and doing a full lock adjustment before pulling back forward (sort of a three point turn out of the M5 spot). It is extremely minor and I do not notice it pulling into the garage.
If you remember the old cars when the PS pump would whine at full lock and if you just let 1 ftlb of pressure off the lock then it would be quiet. Same, just don't try to muscle the wheel at lock and it won't rub.
Appreciate 6
      09-24-2020, 09:11 AM   #8
Used2be
Perennial PFC
Used2be's Avatar
Michelin PS4
295/35/20
305/35/20
Thanks for the info. I'm amazed the 295/35 fits so well, but that takes away my worry for the 295/30. I'm concerned with the clearance when the wheel is loaded during a turn, but the distance gained with the 30 series should do the trick. Plus, you look lower than I am as well.
      09-24-2020, 10:22 PM   #9
Jonathan G.
Thanks!
Michelin PS4
295/35/20
305/35/20
20x11 +22
20x12 +30
This info and photos are very helpful! Thanks!
The Titan 7 forged wheels are the ones i want so this is particularly valuable insight fo me.
My motivation for wider tires is the greater side wall height for improved ride comfort without going down to 19" wheels.
I therefore will not be lowering the M5 but am also interested in the MSS coils for improved ride comfort on bad northeast roads.
Titan recommends 285/35 & 295/35 but i like how you went 10mm more both front and back.
The other alternative is 285/35 in front and 305/35 in the rear - this would eliminAte any rubbing risk in front lock to lock , but at the cost of greater tire circumference difference between front and back and this increased stress on the awd differential bc of it.
Your stagger of 20mm width difference between front and back also makes more sense than the stock 10mm difference. I cant get over this silliness. Imho, if one is only doing a 10mm stagger, then why bother and have the advantages of a square wheel and tire set up like audi quattro does!
      11-17-2020, 04:29 AM   #10
F90M5C
F90M5C's Avatar
Sweden
155
Drives: 19 F90 M5C,17 F82 ZCP M4
Michelin PS4
295/35/20
305/35/20
20x11 +22
20x12 +30
thanks for the info.I was concerned with the clearance before reading your post.
just to make sure according to this i can run 20X11 front with 275 35 tires and 20X11 back with 285 35 without any rubbing or problems ?
      04-20-2023, 01:41 PM   #11
916_M5
IG: @M5RCY_
916_M5's Avatar
Drives: BMW F90 M5
305/295 here
are you lowered? do you get any rubbing?
Autotecknic.com - code: M5RCY for 12% off
Project Gamma - code: M5RCY for 5% off
Dura-Coating - code: M5RCY for 20% off
