Car Freaked out on V7.1
09-20-2020, 04:46 PM | #1 |
2685
Rep 4,202
Drives: '11 335is | '16 Macan Turbo
So I'm gonna need some new leather seat cleaner cuz I just shit myself earlier.
Have been running v8 stage 2+ since forever, v7 before that etc. I wanted to flash back to 7.1 from v8, only other thing I changed was putting cold start back on. I had it turned off for a little over a month only. Put the RB external on with stock flapper hose (no head port plugs yet). After flashing the car stumbled like absolute crazy, finally about 10 seconds later the cold start kicked in and then reduced engine power and fan went max. I just changed the water pump ~5k ago, hence the . Turned off and flashed back to v8 but stage 0, with cold start and no problems at all. WTH happened?! That's a first for me.
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete |
09-21-2020, 02:42 PM | #2 |
2685
Rep 4,202
So my car does NOT like cold starting at all now, still on stage 0 and it was stuttering for a few seconds before cold start kicked in. I know it's not misfire related, plugs and injectors are brand new with coils at 50% life, no codes and drives fine. Feeling like my o2 sensors are starting to go
09-21-2020, 03:11 PM | #3 |
2002
Rep 3,731
What do you mean coils are at "50% life"??
Also...if it was me, I would pull the plugs after letting the car sit overnight...see if any injectors are leaking. Are the injectors new BMW...or "new" remanufactured ones? Welcome to the N54.....get used to troubleshooting issues, it's pretty common with these motors. |
09-21-2020, 03:24 PM | #4 | |
2685
Rep 4,202
09-21-2020, 03:25 PM | #5 |
2002
Rep 3,731
Why are you running a stage 0 tune if the car has the Bolton's for a stage 2 tune? Have you tried going back to a stage 2 tune?
What else changed? You said you installed the RB extremal PCV setup? Could you have a vacuum leak somewhere? Or have something not installed right? |
09-21-2020, 03:46 PM | #6 | |
2685
Rep 4,202
09-21-2020, 03:50 PM | #7 | |
973
Rep 3,219
If your car doesn't like cold start, you can disable cold starts using MHD Personally only ran V9 and V7.1 (current map) never had any issues with them. My car in fact runs better with cold start on. Only time idle went crazy is when I reset the throttle adaptations and didn't wait 30 seconds before starting the car up, easily resolved. |
09-21-2020, 03:53 PM | #8 |
2685
Rep 4,202
Please read OP
09-21-2020, 03:54 PM | #9 |
2002
Rep 3,731
With DP's (and the other bolt ons).....doesn't it need to be on a stage 2 tune to even run right? The stock fuel/spark tables are not setup for any mods....... especially not DP's.
09-22-2020, 12:22 AM | #10 |
973
Rep 3,219
I did, if its running fine without cold start, have you tried flashing a tune without cold start?
Are you saying v7.1 and V9 with or without cold start, don't run properly in your car but V8 which has been reported by many people to be problematic does? |
09-22-2020, 12:01 PM | #11 |
2685
Rep 4,202
I've been running MHD stage 2+ for a few years. Cobb before that. Been on v8 stage 2+ for a long time. A while ago I took cold start off just for a break... STILL on stage 2+! Put external pcv on. Flashed to 7.1 stage 2+ but with cold start turned back on again only after having it off for a month or two. CAR FREAKED. Flashed to v8 stage 0 for the first time! With cold start and still unhappy. I need new o2 sensors.
09-22-2020, 12:23 PM | #13 | |
973
Rep 3,219
09-22-2020, 12:27 PM | #14 | |
2685
Rep 4,202
Wasn't interested in trying out another beta map for no reason, v7 or v8 ots is totally fine for me while I'm updating car with new mods.
09-22-2020, 12:32 PM | #15 |
54
Rep 174
Sometimes this happens to me, usually during a slightly low battery charge cycle. Usually if I hear the fan ill turn the car off and reflash, that fixes it.
7.1 Changes some of the internal settings, i can't tell you exactly what but my car always reacted weird on 7.1. Have you tried 9.0 stg2? Leave the cold start on, and try driving it around for a few days and see if that fixes everything.
ARM CP, DP, 7.5 FMIC, TiAl Q Bov MHD Stage2+/xHP/xDelete Road to 500hp daily on the way (ya right lol) -------------------------------------------------------- |
09-22-2020, 12:55 PM | #16 | |
469
Rep 1,536
I don't know what makes you think your O2 sensors need replacing but if that's your attitude to people helping you then go knock yourself out with new parts. |
09-22-2020, 01:51 PM | #17 |
1209
Rep 2,476
If I'm reading your posts correctly, your problem started directly after installing the external PCV while simultaneously flashing 7.1 with Cold Start On. Is this correct?
Did you run the car after the PCV install, but before the 1st flash after installing the PCV? What did you use as your vacuum reference/OCC return for the external PCV? Was it RB's throttle body adapter, or did you drill/tap a port somewhere? |
09-22-2020, 01:57 PM | #18 | |
2685
Rep 4,202
2. No. Was flashed on v8 stage 2+ (no cold start) during install meaning was running that before as well. 3. RB adapter. No head ports plugged. Didn't change anything from yesterday and just ran some errands. No cold start issue now, still v8 but stage0. Will put stage 2+ back on with v8 and see. I'm perplexed again now. Car has 110k original o2 sensors with many miles tuned so that's what I was really leaning towards, them just on the cusp of starting to go bad.
09-22-2020, 02:06 PM | #19 |
1209
Rep 2,476
Curious, I'm not tuned, so I don't know...does a map flash reset fuel trims? Is it possible you've had a mild, underlying issue that the DME has been able to adapt to making it unnoticeable? Maybe, if it does, is why you experienced issues after the flash and now the DME is beginning to adapt again?
feuer4275.50 |
09-22-2020, 10:55 PM | #20 |
4276
Rep 9,206
Who made this dumb recommendation? Would 5k hwy vs 5k city vs 5k track yield equal life span? Just curious....
09-23-2020, 11:05 AM | #21 | |
2685
Rep 4,202
But don't worry, I'm getting new coils from FCP for lifetime and change them with oil soon for the hell of it so everybody can sleep easy at night that my coils will be brand new as well
09-25-2020, 07:07 PM | #22 |
866
Rep 5,452
There have been a few other posts in the last year or so I have read with weird issues after turning cold start off and back on - maybe see if you can find them, seems there is some weirdness around changing cold start on some cars.
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
