10-04-2008, 10:50 AM | #2 |
135
Rep 2,120
Drives: ///M Roadster + E92 335i 6MT
M or Regular Z4?
Actually easier just telling you both, For the non M half moon looking ones there is 2 10mm nuts holding the reflector on from behind, You can get to them from the headlight/foglight access panel its a little tricky but can be done, The M is slightly easier, again you will need the headlight panel in the wheel well off (easier if you take the wheels off for ******* and you push from the front of the reflector and they are just held on by double sided tape, BUT Try not to drop them as you push them in, If you drop them they are a PITA to retrieve you have to push them and hold them from the back at the same time, are you painting them?
Imola Red Roadster |
