09-09-2020, 10:00 PM | #1 |
2019 BMW X5 iDrive 40i M-Sport
8
Rep 22
No Tire Rotation on Run Flats?
Hi All, just had the one year service done on our xDrive 40i, and our dealer said they don't rotate the tires. When I questioned, they said its because of the camber setup & there's no need to rotate. Has anyone else encountered this with their dealer? It's not a staggered set-up. I don't see how it's not possible to get some rounding on the fronts compared to rears over time. We're on the 20 inch M rims with Bridgestone Alenza's.
09-10-2020, 01:13 PM | #2 |
252
Rep 236
I'm not sure about run-flats on X5, but I never rotated run-flats on an X1 and they wore down almost identically.
Regardless of type of tire though - I remember seeing an estimate of rotation $+time cost vs presumed gains in longevity, and the winner was no rotation. |
09-10-2020, 11:48 PM | #3 |
Driver
163
Rep 447
May also be an awd thing. On a fwd car or rwd car you would definitely see more wear on the driven wheels, and rotation would make sense. For a car where all for are driven there is likely a lot less difference in wear, so rotation would have no real benefit (assuming proper alignment, etc,)
09-11-2020, 07:51 PM | #4 |
34
Rep 55
I spoke to the service manager today when I ordered my M50i. This topic came up and he said the base runflats I am getting should last about 20k miles and not to rotate them unless I do it before 5k miles. He said because of the rear tire settings (I think it was camber) it would cause those tires to wander and not track well on the front.
2021 X5 M50i
Other vehicles: 2019 Corvette Z06, 2019 RAM Longhorn, 2018 Acura RLX, 2002 Pontiac CE Trans Am, 1988 Pontiac Fiero GT |
09-12-2020, 01:24 PM | #5 |
8
Rep 22
Yes, it was the camber issue. They said the due to how they have the camber setup the tires benefit from not being rotated. Thanks all for responding - wanted to make sure it wasn't a dealer ideology.
09-16-2020, 03:35 PM | #6 | |
422
Rep 982
On my wife's F15 with 19" square setup, wear seems to be pretty even. Not enough time on my summer and winter 22" on my M50i yet to see how they will wear. |
