09-07-2020, 02:50 AM | #1 |
Rep 3
E92 335 question: My car rattles/shakes and cant be driven "sometimes" in the morning
Hi everyone
Apologise in advance if I don't explain this right, but ill try my best to explain the issue i am having with my 335. In short, the car starts to shake or rattle first thing in the morning (if, and only if, I let it idle). If I start the car and let it idle, the following happens: 1. within 10 seconds, i start to feel the car begin to shake or rattle (at first it is not severe); 2. the closer it gets to the stage of when the second second exhaust opens up, the shaking gets worse; 3. after the second exhaust has opened up and both exhausts are on (this usually occurs after you hear the waste gate rattle), it will usually start sounding like its choking, and the yellow engine light turns on. This sometimes results in the car "conking out" or just feels like it should just not be driven. That said, if i turn the ignition, and immediately start driving the car, I don't get any issue at all. The mechanic originally thought it was the sparks plugs, but they have been replaced twice and the issue is still there. Does anyone know what it could be? |
09-07-2020, 04:39 AM | #2 |
35
Rep 51
Highly recommend getting the car scanned by a professional or someone who knows what they're doing with a scan tool. Will be blind guesses otherwise. If it's thrown the engine light it will have the code stored and allow you to narrow the issue down. Could be anything from coils, fuel injectors, a vacuum leak etc.
erawamai161.50 |
09-07-2020, 08:48 AM | #3 |
Rep 3
My mechanic already did that, and the fault code indicated it was a spark plug. So changed that, and the issue went away for about 2 weeks and then came back. He reckons it might be the injectors, and if so, will need all of them replaced.
Apparently you need all replaced, and each one costs $700 or something ridiculous. I have had the worst luck with this car. Had to pay for both turbos to get replaced at 91 KM's. |
09-07-2020, 05:45 PM | #4 | |
35
Rep 51
09-09-2020, 02:43 AM | #6 | |
JDTuning
216
Rep 907
I have a lot of experience with tuning and unfortunately (lol) troubleshooting problematic N54's. If you are based in Sydney, I can arrange to have the issue investigated thoroughly for you. Out of curiosity when the engine stumbles after a cold start, does the exhaust gas smell very fuely? Thanks, Justin. |
Tags |
bmw 335i help |
