09-06-2020, 07:21 PM | #1 |
Rep 2
X5 wheels on X7
Have a 2020 x7 M50i, 22 inch wheels, dynamic handling package. Wanting to purchase new winter wheels and snow tires. Will 21 inch OEM from an X5 cause any probs?
09-06-2020, 08:09 PM | #2 | |
4362
Rep 4,246
Assuming you're using a 9.5" x 21 square setup, difference is X5 9.5" x 21 has an offset of 37mm versus X7 9.5" x 21 offset of 36mm. 1mm shouldn't be an issue and may stick out slightly depending on the tire. 21" X5 wheels are a bit expensive for snow wheels. You can also go down to 20" for more wheel and snow tire options. The least expensive 2" snow tire in 285/45R21 is Bridgestone Blizzak LM001 113V XL RFT.
Current BMWs - '20 X5 xDrive40i M Sport, '20 BMW M550i | Past BMWs - '03 E39 540iT M Sport, '06 E53 4.8is, '11 E70 M Sport LCI
09-06-2020, 09:29 PM | #3 | |
111
Rep 376
Also the wheels will be I. The system where you specify the current wheel tire. |
09-10-2020, 06:00 PM | #4 |
309
Rep 579
I'm trading in my X5 in 2 days for a X7 M50i and have a set if 3rd party wheels with winter tires on them, they are 22s and staggered on my X5, will they work on my new X7?
