09-03-2020, 04:59 AM | #1 |
19
Rep 62
Suspension Question
Hi all,
I took delivery of my new BMW X5 40i and after a few days of driving it I found it a bit harsh on the road while in comfort mode. I don't have the adaptive 2-axle air suspension (2VR). Only the adaptive M suspension (2VF) which when choose it it's a bit better. Also I have the 740M 20'' wheels with runflat tyres (If it has something to do with it). Any recommendations for a smoother ride especially in the city with road noise? |
09-03-2020, 05:51 AM | #2 | |
1091
Rep 2,420
Are the road in Cyprus in bad condition? Did you do a test drive with the configuration you ordered? I don't think you can do much. The 20 inch wheels are supposed to be more comfortable than 21 and 22. Maybe switch to non run flats might give a bit better comfort. But that will cost you a lot of money. And the current rft tires are more comfortable then the older ones. Switching to 19 inch non RFT's? But that is not good for the looks. |
09-06-2020, 11:03 PM | #4 |
265
Rep 479
I don't think the OEM run flats are that bad. I've had both Continental and Bridgestone and both were very comfortable. That said all run flats have stiffer sidewalls so switching to a non-runflat tire with more compliant sidewalls will certainly improve the ride comfort but by how much is hard to say given how good the OEM tires are. Regardless of tire, i don't think it will completely satisfy you. Air suspension is what is needed to make a real difference in ride comfort. Air is like a night and day difference on rough roads.
09-07-2020, 05:22 AM | #5 |
1340
Rep 1,240
I have air suspension..... and acoustic glass..... and I was CONVINCED when I bought my car that I'd made a mistake. I couldn't figure out why a car equipped with those options would be so noisy and so bumpy.
After 300 miles, I removed the Summer Continental runflats, and installed a set of All-season Pirelli non-runflats. Night and day difference. I still have the set of almost-new runflats sitting in my basement, and I'd rather ride on bald tires before I put those POS' back on my car. Granted, the OEM tires were Summers, and my Pirellis are All-seasons.... But I also just installed significantly wider 22" Summer non-runflats on a new set of wheels.....and even those are smoother and quieter than my OEM 21" runflats. That's how bad those runflats are. |
09-09-2020, 04:32 AM | #6 |
19
Rep 62
Thank you all for the responses. I am sure when I change my tires I will go for non RF. The dealer told me that I will get a smoother ride with non RF but when the car corners the RF are more stable. For the moment I drive with the adaptive suspension and get a smoother ride.
09-09-2020, 10:01 AM | #7 |
127
Rep 242
Run flats
I agree on the run flats being harsh. They come standard on the Corvettes and I always changed them to standard tires which made it much smoother.
