Front Sway Bar End Link Support
08-31-2020, 03:20 PM | #1 |
22
Rep 88
Best way to remove the bottom 16mm nuts if they’re seized? Used PB on them, 16mm and 17mm together, breaker bar on the outer 16mm nut. Impact wrench is too big to fit in there. Even with a swivel socket the control arm seems to be in the way a bit. Thought of removing the end link off the joint and attaching a deep 17mm socket on the nut with a breaker bar. I really don’t want to buy another impact wrench because who knows what will fit up in there. Don’t really want to get a tool to cut it off either. Thinking of biting the bullet because I’m installing the Lemforder links and they require a T30 which I have, but I’ve read it can be a real hassle to try and torque them to spec unless you have a crowfoot wrench. Has anybody had any luck removing these with a certain impact wrench? And has anybody had experience with the Lemforder links that require the T30. At this point I’m about to take it someplace cause it’s becoming a hassle.
08-31-2020, 10:10 PM | #2 |
Rep 60
The best I could do was PB blaster several times and wait an hour. Jack up the car, can use both side front jack point and front center jack point and then use the breaker bar or a hammer on a wrench. A good whack with the hammer on the wrench should provide just enough torque to break it loose.
09-03-2020, 11:59 AM | #3 |
69
Rep 113
If you cant get it off with the tools you have. just cut it off completely. I'm about 50/50 for salvaging peoples sway bar links this year. (I live in Maine) The part is not expensive. Its cheaper to replace it yourself then it is to take it some where, and to have them end up doing the same thing.
09-05-2020, 06:27 AM | #4 | |
22
Rep 88
