How to identify staggered wheels
08-26-2020, 08:22 PM | #1 |
Robot
1691
Rep 2,192
Is there an easy way to quickly identify which wheels are wider or narrower on a staggered wheel setup?
I recently acquired a 330i with sport package that has type 162 wheels (Front: 18x8 225/40 R18, Rear: 18x8.5 255/35 R18). While the tires are correctly positioned on the car, I suspect that whatever shop the previous owner used mounted them on the wrong wheels. My front tires are 225/40R18 and it looks like the tread is narrower than the wheel with the sidewalls stretched out to fit the rim. My rear tires are just the opposite, 255/35R18 overhanging the lip of the rim quite a bit. I suspect that the 8.5" wide wheels are up front and the 8" wide wheels are in the back. Is there a quick way to identify this? I looked for markings but couldn't find anything. |
08-26-2020, 08:44 PM | #2 |
305
Rep 166
The size markings are on the inside of the spokes, you’d have to remove the the wheel to verify.
You can use a measuring tape on the inside lip of the wheel, there’s more clearance around the bottom of the wheel between the spokes to get a measuring tape in there, measure from the inside to a reference point on the front and compare the wheel widths of the front and back wheels and you’ll see which are wider. |
08-27-2020, 03:47 PM | #3 |
Robot
1691
Rep 2,192
I just took the wheels off and confirmed my suspicion. Sure enough the 8" wheels were in the back and the 8 1/2" were up front. This ain't no Audi RS3! (wider front wheels)
I had them swapped and rebalanced, looks way better. What a weird screw up by the previous tire shop. Somebody wasn't paying attention. |
