08-25-2020, 05:14 PM | #1 |
277
Rep 266
Drives: '89 Land Cruiser, '18 M2
2018 LCI at CarMax Parker
Hey guys,
Test drove a 2018 M2 this early afternoon. Pulled fantastic, brakes were great, rear tires felt a little worn in the rear (measured to a 4). However, I popped the hood and I found fluid pooling in two areas of the engine bay. Very odd in my opinion, not sure what to think of it and thought others could chime in. It's listed at $46k with 10.6k miles on it. If i can get a credit for the rear tires needing to be swapped and some curb rash I am thinking I might pull the trigger, but am slightly nervous about the fluids. Check out the video and let me know your opinions: Last edited by bngcruiser; 08-25-2020 at 05:20 PM.. |
08-25-2020, 05:15 PM | #2 |
277
Rep 266
Trying to get a working link:
08-25-2020, 05:19 PM | #3 |
277
Rep 266
I am usually pretty computer literate .. no idea whats going on here.
Trying YouTube |
08-25-2020, 05:41 PM | #4 | |
Leased
74
Rep 28
Look under the hood, see if there's a residue coming out from the points that correspond to where you see the oil on the headlight and engine bay. As I understand it, it's from the paint process and it happens when temp heats up. |
08-25-2020, 05:44 PM | #5 | ||
277
Rep 266
There is fluid run and dried on the headlights, same fluid. Hard for me to understand that it's coming from the hood ... why is there fluid in the hood, the hood struts?!!?
08-25-2020, 05:59 PM | #6 | |
Leased
74
Rep 28
It's a solvent being used during the painting process and could reappear under heat. Also you might notice a crayon like smell as well. If you can get another look at the car, just check under the hood and see if there's the same residue there. |
08-25-2020, 06:01 PM | #7 |
277
Rep 266
Thanks guys, this makes a lot of sense. It was 98 degrees out and I drove it hard (for a test drive, of course).
Guess I've gotta have that talk with the wife then.
08-25-2020, 06:24 PM | #8 |
10665
Rep 6,939
Drives: 2018 M2 AW DCT
Take it to a BMW dealer or independent BMW shop and get an inspection. Better safe then sorry.
08-25-2020, 06:26 PM | #9 |
277
Rep 266
CarMax gives me an opportunity to return the car 7 days no questions asked - which seems too good to be true. I would certainly go to my Indy shop immediately and get a good opinion before keeping the car.
08-25-2020, 06:27 PM | #10 |
10665
Rep 6,939
I would do it before purchasing the car. Cheap peace of mind.
bngcruiser277.00 Altra265.50 |
08-25-2020, 06:46 PM | #11 |
on restriction from buying more cars
239
Rep 186
On the hood there are spring buttons next to the U-shaped metal. They are a little oily on my car with ~12k miles. You can see a little circle of oil/grease in the second photo where they touch. But it’s not oily like in your vid. I touched the same areas and my fingers were clean and I don’t have any oil on my headlights.
bngcruiser277.00 |
08-25-2020, 08:15 PM | #12 | |
1640
Rep 906
OP - I bought my 2018 OG BSM at CarMax Broadway. I did the inspection after my purchase. As long as you don't destroy the car you'll be able to return it if you don't like what your Indy finds. That said, I kinda hope you don't buy. I like having the only 2018 OG BSM in Denver.
2009 328i xDrive 6MT (Retired and I miss her)
2015 335i xDrive 6MT (Retired and I dont miss her) 2018 M2 6MT (Never retiring) |
08-25-2020, 09:49 PM | #13 |
10931
Rep 4,551
Drives: 2015 328d xDrive
Pretty sure it's just left over cosmoline from overseas shipping leaking from the inside of the hood onto the outer edge of the engine bay. My car does it every so often, mostly in very hot weather. In my case you can see it's clearly coming from the holes in the hood.
08-25-2020, 10:06 PM | #14 | ||
277
Rep 266
08-26-2020, 09:28 PM | #15 |
908
Rep 1,110
Drives: M3CX
Maybe someone spilled some oil during the last change and did a crappy job cleaning it up.
08-27-2020, 10:03 AM | #16 | |
134
Rep 177
If you buy it, immediately take it for inspection for peace of mind. Can always return it if it fails the inspection. |
08-28-2020, 04:43 PM | #17 |
1640
Rep 906
So are you buying this thing or what? I don't see it on Carmax website
08-31-2020, 08:24 AM | #18 |
Occasionally frequent poster
3000
Rep 2,744
$46K with 10K miles needing tires seems expensive to me...
Current inventory:
F22 & G05 Cadillac CT5-V Blackwing w/3 pedals Past: E24,E28(3),E34,E36,E37,E38(2),E39(4),E46,E89,E92 (obviously),F01,F06,F10,F30,F87,G12,G30(2),G82(2) |
cactusjack370.50 |
08-31-2020, 08:25 AM | #19 |
277
Rep 266
I agree, they aren't budging on price. Not sure I'm coming home with it.
08-31-2020, 09:03 AM | #20 | |
1640
Rep 906
Proved to be a good move...this is the first low mileage 6MT BSM LCI I've seen pop up since I bought back in February. Don't let a few hundred Dollars get in the way of what you want...it's nothing in the grand scheme of life
bngcruiser277.00 Poochie9104.50 |
08-31-2020, 09:06 AM | #21 | ||
277
Rep 266
I'm not afraid to fly and drive but you are correct, I want BSM manual - however, this is a "fun" car for me and I've gotta believe the market will be in favor come cold weather time.
08-31-2020, 12:38 PM | #22 |
793
Rep 1,367
The whole idea of a pre-purchase inspection is to do IT PRE-PURCHASE so you can negotiate the price down to cover the issues
Doing an inspection AFTER purchase seems counter-intuitive to me - even if you can return the car within 7 days |
