08-23-2020, 04:05 PM | #1 |
22
Rep 44
Drives: 2020 M2C
Vibrations at highway speed
Hello,
Have a question about steering wheel vibrations. Going at highways speeds in my M2C, the steering wheels shakes a bit. Not the normal vibration/road surface shake but something like the wheel balance/alignment is off. In city speeds, it is fine. So I'm wondering if it is more of the wheels need to be re-balanced vs alignment? Thanks |
08-23-2020, 04:21 PM | #3 |
3907
Rep 4,048
Drives: 2020 M2C, 2019 330xi, 2017 Q7
Yeah, there shouldn't be a vibration. Normal rumbling through the steering is normal but not vibrations.
08-23-2020, 04:22 PM | #4 |
10686
Rep 6,938
Drives: 2018 M2 AW DCT
Sounds like you need your wheels rebalanced.
08-23-2020, 04:58 PM | #5 |
53
Rep 155
I get a vibration in the steering wheel starting at 120 and gets worse at 140 km/h+. It's bad enough that it completely overcomes the vibration from lane assist, but not bad enough to blur the rear view mirror.
My wheels are road force balanced, but tyre guy says my tyres are out of round. Last edited by blitzyo; 08-24-2020 at 02:10 PM.. |
08-23-2020, 07:19 PM | #7 |
259
Rep 151
Been there, done that. Had a very slight vibration in the steering wheel. Dealer looked at it and said it was normal. I persisted, and they rebalanced the wheels under warranty. The result was zero difference. It's a stiff car, and I've accepted that some level of vibration is normal. I tell myself it's the price to pay for what little feedback is left in modern steering systems. Since then, I've noticed the road surface seems to make a big difference in the vibration, so I suggest you try a different road if you haven't already done so. If it happens on every road, it's definitely worth getting it checked, but don't be shocked if it is determined to be "normal".
2019 M2 Competition 6MT - ED October 5, 2018
2018 Honda Accord Sport 1.5T 6MT (daily driver / family hauler) |
08-23-2020, 08:34 PM | #8 | |
10686
Rep 6,938
08-23-2020, 09:35 PM | #9 | |
1996
Rep 1,759
08-23-2020, 10:03 PM | #10 |
22
Rep 44
Drives: 2020 M2C
Thanks for all of your inputs. I will have my wheels rebalanced as a wheel weight might've fallen off. The car tracks straight with hands off the wheel so it isn't an alignment issue
08-24-2020, 12:54 AM | #11 | |
253
Rep 179
-2020 M2Cs
-2020 GLS450 |
08-24-2020, 06:16 AM | #12 | |
4450
Rep 7,594
Drives: '19 M2C
Take it somewhere else and have them check your wheels for balance and they are true.
www.ReTuneTheDeTune.com
2019 M2 Competition (Sunset Orange) |
08-24-2020, 03:16 PM | #16 |
Luxury at the redline :)
9105
Rep 7,563
08-24-2020, 04:17 PM | #17 |
Rep 18
I had an Audi rs3 which was a very stiff ride. Got vibration at about 75mph. Tried rebalancing a few times to no effect but then read about road force balancing etc
Found a garage with the right equipment. He put my wheels on without the road force attachment/arm and they were all reasonable well balanced. As soon as the road force arm was put on all wheels were quite a bit out and needed rebalancing to suit. Ride home.....first time 0 vibrations. Quite a common issue with stiff suspension cars which often have large alloys and therefore stiffer tyre wall section tyres to suit |
08-24-2020, 05:33 PM | #18 |
5560
Rep 2,298
if the dealer isn't fixing it properly, i would check out a proper alignment shop to see if they can rebalance or hell, even a discount tire.
Present: 2023 M2 BSM W/Carbon everything, 6 Speed
Past:2020 M2C HS Executive, 6 Speed |
08-24-2020, 06:29 PM | #19 | |
9105
Rep 7,563
When a high-speed, Hunter Roadforce equipment is used, it spin-balances the wheels up to 100mph of testing. Hence the reason the lower-end shops, without the high-speed equipment, does a poor job of smoothing out wheel weight imperfections, at higher speeds. Moral of the story: find a shop that uses high-speed, wheel balancing equipment only. |
BMWM5NYC496.00 |
08-25-2020, 12:41 AM | #21 |
184
Rep 364
Drives: M2C X5M M4
Ask them to spin them slowly to check for buckles too, sorry if it's been mentioned above.
08-25-2020, 06:04 AM | #22 |
4579
Rep 4,684
Do you track your car? Was watching a video of Joe Achilles at the EBC shop. In the discussion they touched on the BMW rotors not being fully free floating and when worked hard can not return to neutral position. It causes a vibration. I'm guessing it causes the rotors to be slightly out of balance.
