Bimmerpost
4 Series
Technical Topics Suspension / Chassis / Brakes BMW m340iX G21 upgrade to G3X M-performance brakes
      08-23-2020, 10:25 AM   #1
Duckmann
Drives: G21 M340iX
Hi
Upgraded my front brake setup to the G3X M-performance calipers and 395mm rotors.
This is a bolt on upgrade, you only need to modify the dust plate a bit with a screwdriver.
Also upgraded the rear rotor to the dotted version.
Front calipers partnumber: 34106880679 + 34106880680
Front rotor partnumber: 34106887657 + 34106887658
Rear rotor partnumber: 34206896227 + 34206896228
Big thanks to blau3er for supplying the calipers and pads!
And yes, the car needs a wash
Appreciate 2
      08-23-2020, 10:30 AM   #2
blau3er
1147
Drives: F31 30d
Awesome!
Looks great and I’m fairly certain that you are the first G2x owner to do the 395mm front upgrade from G30 G11 etc.
So much better than the M Performance option!
      08-26-2020, 01:24 AM   #3
Frederik
Drives: BMW 435d
Looking very good!
Did you code the brakes in the software after fitting?
How is the pedal feel and the balance of the car when braking?
keep up the good work
      08-29-2020, 11:19 AM   #4
Duckmann
Drives: G21 M340iX
Thanks!
No coding, and the brake feels 90% the same, hard to tell when not trying the car vs a stock M340 back to back. Balance is good, no complaints.
      08-29-2020, 01:57 PM   #5
OM3RTA
United Kingdom
391
Drives: 330i M Sport, Audi A3 2.0 TDI
Looks great.
Almost did this myself using those calipers from the same seller but have decided to hang back for now & go 374mm as I want to keep the weight down.
One question why is it only the rear disks have the slots??
      08-31-2020, 05:33 AM   #6
Duckmann
Drives: G21 M340iX
Thanks!
I was considering the same thing, saving weight! - But again, it is a daily driver, and not at track weapon
OEM discs, and it seams that I cannot get slotted front discs, or I was not able to find the correct partnumber.
OM3RTA391.00
      01-02-2021, 12:21 PM   #7
kemiksiz
kemiksiz's Avatar
Turkey
380
Drives: BMW
Very nice & gonna seem excellent after it got dirty 😁
I have also swapped p&p 850i brakes, 395mm but plane discs.
Wondering if M8 setup will be bolt on?
      01-02-2021, 06:43 PM   #8
blau3er
1147
Drives: F31 30d
M8 would not be bolt on - it would require a custom adapter to mount the caliper onto the hub.
The ///M discs bolt on, but the retaining screws do not line up.
If you want ///M discs, then you can fit X3M / X4M discs to your car with the 395mm caliper you have - however, again, the retaining screw doesn’t line up.
      01-04-2021, 07:04 PM   #9
Boosted6
41
Drives: G80 Skyscraper
or just get these:
https://g20.bimmerpost.com/forums/sh....php?t=1787733
      01-07-2021, 11:22 AM   #10
blau3er
1147
Drives: F31 30d
Originally Posted by Boosted6 View Post
Good luck getting Alpina to give you a part number without a chassis code / proof of ownership - never mind selling a set to use on a non Alpina car!
They are VERY protective of their brand / unique parts...
      02-03-2021, 02:10 PM   #11
dave72
BMW M2
dave72's Avatar
497
Drives: BMW G87 in order
Thumbs up
I have placed 395mm brakes on my G21,
Insta BMW_G21_330e
Appreciate 2
VipinLJ1941.50
OM3RTA391.00
      02-24-2021, 12:26 PM   #12
_Qba_
Drives: G20 330i
Anybody tried to fit rear g30 370mm brakes?
I have opportunity to buy full set from 540i, it's a 374mm front and 370mm rear
Front is no problem, but I'm wondering if rear also fits
      06-27-2021, 06:34 AM   #13
hanselfransel
Germany
27
Drives: BMW
@duckman How did you solve the problem with the retaining screws that do not line up?
      06-28-2021, 09:04 AM   #14
jeegunkim
jeegunkim's Avatar
328
Drives: 2020 330i xDrive, 2023 M3CX
Very nice. Did you guys have to upgrade the brake booster and master cylinder as well? Heard pedal still feels mushy or the same if you don't.
2020 MG 330i xDrive M Sport
2023 AR M3 Competition M xDrive
      07-25-2021, 09:03 AM   #15
FoCoChris
Drives: BMW M340i - G20
Did you find torque specs for the calipers? If you did where did you find the spec so I can find the number for my brakes. (Blue M brakes on the m340i)
      07-25-2021, 10:21 AM   #16
PLF69
PLF69's Avatar
3766
Drives: 2023 M3
Can someone confirm that you need 20inch wheels to run the 395mm setup ? I already have 374mm on my car and I don't see how bigger rotors could fit in the 19inch wheels..
Fun/HPDE: 2023 M3 6MT Individual Malachite
Past:2023 M4 CSL, 2022 M4C Vert, 2020 M340i, 2018 M2, 2015 M235i, 2008 135i 550whp
Daily: 2023 X5 45e
Daily/Family: 2021 Atlas Cross Sport 3.6
      07-27-2021, 07:32 PM   #17
OM3RTA
United Kingdom
391
I've only ever saw it being done with 20" and even then it's supposed to be tight.
*edit* reply was for the rear set up of 370mm.
      11-17-2021, 03:15 PM   #18
Duckmann
Drives: G21 M340iX
As I recall, the screws actually did line up
      11-17-2021, 03:16 PM   #19
Duckmann
Drives: G21 M340iX
No negative brakepedal feel, if any the brake pedal feel is even better, and with 4 people in the car the amount of pressure to stop does not change, I'm very happy with the setup.
      11-17-2021, 03:17 PM   #20
Duckmann
Drives: G21 M340iX
I have 19" inch, not much room left but it fits. But I think it comes down to wheel design.
      08-26-2022, 07:19 PM   #21
bimmerstar
bimmerstar's Avatar
Drives: 2020 BMW M340xi
which brakes do you have front and rear? and what 19" are you running? OEM G20?
      03-06-2023, 01:33 PM   #22
Duckmann
Drives: G21 M340iX
Wheels are these: https://www.litespeedracing.com/vs10
Front brakes are from 5 series, rear is stock but with dotted roters.
g20
