08-19-2020, 07:14 PM | #1 |
53
Rep 130
How to wash engine bay
How should I keep my engine bay clean? Spray degreaser and rinse it with water? Only use water?... I live in an area where there's always dirt
08-19-2020, 08:31 PM | #2 |
22
Rep 87
The last time I used degreaser and spayed with water my dash lit up like a christmas tree with error codes. After I let it dry out in the sun and used a leaf blower to dry it out it was fine but i wont do that again. Sooo dont do it. Or cover all connections you can find with something and hope for the best.
08-19-2020, 11:33 PM | #4 |
53
Rep 130
08-19-2020, 11:38 PM | #5 |
David
786
Rep 2,009
I'd just hit it again lol
08-20-2020, 12:35 AM | #6 |
556
Rep 906
I have done this on my old F30 with the N26/N20 engine.
Needless to say, I experimented on this technique with a loaner F30 first befroe trying it on my own car.
2017 328d xDrive Sports Wagon: Estoril Blue, Black Sensatec, M-Sport Pkg
2020 i3 Rex: Capparis White, Giga World |
imperfectluck426.50 |
08-20-2020, 01:06 AM | #7 | |
David
786
Rep 2,009
08-20-2020, 06:33 AM | #8 |
87
Rep 146
I haven't had any issues using a standard hose sprayer on my engine. Just make sure that it's relatively cool and don't directly soak anything electronic. I usually use a towel or airgun to dry it off. Aside from minor initial belt squeak as it dries, I haven't had any issues.
08-20-2020, 01:54 PM | #9 |
34
Rep 313
Drives: Like a hooligan
Wow, directly hosing down the engine bay seems sketchy at best. I always thought people detailed their engine bays by hand.
2016 F30 340i M Sport | 2009 E92 328i 6MT |
sspade2466.00 |
08-20-2020, 02:09 PM | #10 |
2031
Rep 2,811
Drives: F33 430 and F39 M35i
I haven't hosed off the engine bay at all, I just use a damp rag and wipe stuff down.
At work, our maintenance guy just hoses down the engine compartment of our police cars! |
08-20-2020, 02:10 PM | #11 |
34
Rep 313
Something about a hose spraying directly into the engine bay just seems so wrong to me.
undertaker63.50 |
08-20-2020, 02:14 PM | #12 |
8264
Rep 16,108
Next time you get home after driving in the rain open the hood. The engine compartment isn't at all water tight. What's inside it for the most part is.
08-20-2020, 02:16 PM | #13 |
34
Rep 313
I get that, but surely there's a difference between spray from the wet road while driving and a direct shot from a hose nozzle, no?
08-20-2020, 03:37 PM | #14 |
Rep 29
08-20-2020, 03:39 PM | #15 | |
87
Rep 146
I don't soak anything, just a quick spray to get the gunk off. Definitely don't want to be directing a jet nozzle at your ECU. |
08-20-2020, 04:18 PM | #16 |
481
Rep 1,572
For 20 years I use a spray engine form de-greaser on a cool engine bay. Let sit for 5-10 minutes, then spray clean with a water hose with nozzle on a medium wide spray. No issues on any of me cars in years. Now on my older cars with Points and Distributor- that"s a different story!!
08-20-2020, 08:58 PM | #17 |
8264
Rep 16,108
The intake is tight. It pulls its air supply from the lower right grille near the right foglight. There's a weep hole to drain any water that makes its way up near the filter, but that's on the bottom of the intake. If you're concerned about where wiring is inserted into connectors give them a spritz with WD40.
08-20-2020, 10:18 PM | #18 |
2466
Rep 5,457
Drives: F30
I start with a dry vac of the obvious areas and then go to town with a damp microfiber and maybe some glass cleaner.
Spraying it down with the hose would probably be fine as long as you don't go crazy... I just haven't found the need. |
08-20-2020, 10:28 PM | #19 | |
339
Rep 660
Drives: 2014-320Xi / 2017-330Xi
So I did the process you mentioned above... No drama, just be careful to not spray sensitive areas, like electrical connectors. Spray the foam de-greaser and 10 minutes after a good spray of water will do the job. |
08-20-2020, 10:53 PM | #20 | |
19
Rep 51
I usually lightly spray the shock towers and front area, pretty much the painted parts. Sometimes I use soap and a sponge also. The plastics can all be removed and cleaned separately if needed. The main thing is to try not to completely soak the engine, especially the ECU area. I've de-greased the front and sides of the engine with the hose on low pressure with zero issues. I learned early on the f30 doesn't seem to like having its engine bay drenched in water. haha Last edited by delorean175; 08-20-2020 at 11:09 PM.. |
08-21-2020, 12:41 PM | #21 |
153
Rep 258
I use an easily-found degreased called Purple Power. Wear gloves and glasses when you spray it.
It's best if engine is a little warm but NOT hot. Never put water on a hot (that is, fully warmed up) engine. Remove the beauty cover. Wet engine (you don't need jet spray) then liberally spray on the purple power. Give it 10 to 15 minutes, then rinse. You can scrub stubborn areas, but usually that's the fluid reservoirs and I follow up with other cleaners and a towel. Pointers: Don't spray purple power on painted surfaces, although I've sprayed painted areas under hood without damage, it's a bad idea. On N55 engine, if you get water into the Wells next to the spark plug wells, the water Won't come out until the engine gets hot and boils it out. The oil filter housing is aluminum and it oxidizes. Purple power won't help much. It will get rid of oil drips but I don't know how to shine that aluminum. The beauty cover and other plastic, like the tough to clean fluid reservoirs, can be wiped with Armor All or similar. Here's my engine after six years and 50K mi |
Phoenix70486.50 |
08-21-2020, 04:42 PM | #22 |
132
Rep 35
I used a hose with sprayer attachment to rinse it, used a brush on the really dirty areas, rinsed off the excess. Air dried it with a leaf blower and then went in again to dry it completely and wiped it with Black Magic (Chemical Guys). I only covered the alternator. That was a couple of months ago.
Phoenix70486.50 |
