Bimmerpost
4 Series
Technical Topics Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin M340i high pitched sound after hard driving?
      08-13-2020, 11:31 PM   #1
SemtexGT
Romanian Spy
SemtexGT's Avatar
Romania
64
Drives: 2020 M340i xDrive
Hello!
I have my M340i for about a month now and I've put about 3000 miles on it, runs like a dream, but I've noticed this 3 times already, after I drive it hard and the engine gets hot I hear in the cabin a wierd high pitched sound, like a kettle on the stove or something like that, which doesn't necesarilly seem to have any connection with the rpm I'm at.
Anyone have any ideas what it might be? Thanks for the help!
      08-14-2020, 07:10 AM   #2
themnmd
themnmd's Avatar
Drives: 23 X5MC
While still running or after turned off? Only thing I have heard is fan after turning off. Have you opened the hood to look for coolant leaks? I was thinking a steam leak from a hose or on coolant system? Also is AC on or off
      08-14-2020, 07:57 AM   #3
SemtexGT
Romanian Spy
SemtexGT's Avatar
Romania
64
Hi! Only when it is running, when I turn the car off it disappears and doesn't seem to have anything to do with the AC because I hear it even when I turn the AC off. I'm going to check for leaks. I opened the bonnet a few times before noticing this and saw some milky stain spots on the engine cover... could it be coolant?
When I saw it I thought it might be coolant, but the car didn't throw any codes, so I didn't think much of it
      08-14-2020, 02:44 PM   #4
themnmd
themnmd's Avatar
Drives: 23 X5MC
I am not a mechanic but I seem to remember that milky means oil and water mixing. I hope not! I would say take to dealer to check it out. I assume it's under warranty
      08-17-2020, 11:47 PM   #5
Tskyline
Tskyline's Avatar
Drives: G20 Bmw 330i
Hi there is it smthg like this?
TK
      08-18-2020, 04:22 AM   #6
SemtexGT
Romanian Spy
SemtexGT's Avatar
Romania
64
No, nothing like that. It sounded something like my ears were ringing, but very slight.
Hasn't happened since I posted this, so maybe I was just being hysterical.
      04-16-2022, 08:33 PM   #7
SouthFLJoe
Drives: 2020 BMW M340i
Hello!
I have the same issue. Just brought it in to the dealer. Ever figure out what happened from this?
      04-16-2022, 08:37 PM   #8
SouthFLJoe
https://youtube.com/shorts/i6BggquNz6M?feature=share
This is a decent video I took
      04-17-2022, 08:25 AM   #9
jbarba
jbarba's Avatar
Spain
44
Drives: G21 320i
try to replicate the sound with a completely emptied car: take all things out of the car (including the tow tools in the trunk).
Open the bonnet and check if engine protection is tight. Have you tried to reproduce it while stopped? I mean, if you get rpm hight enough while parked, the weird sound comes?
      06-20-2023, 05:21 AM   #10
vicash
Drives: BMW 330D G20
Haaving the same issue, did you find out what was the root cause?
g20
