TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > 2008 335xi: How do I raise the back end? Bilstein B6 and Dinan springs
      08-13-2020, 08:44 PM   #1
apexxx6789
Drives: 335XI
Shocks / struts were blown out, decided to replace them with Bilstein B6s. Front end raised from 26.5 to 27, back end was at a 2 finger wheel gap, I know a very accurate description, and stayed there.
Did not like the front raised so much so replaced springs with Dinan -.5 front and 0/ no change in the back. Front settled at about 26.75 but the back end settled about .25 inch at first and now is probably down .5 inch lower. How do I raise the back end up a bit?
I know Dinan recommends Koni shocks.
I did not use the Dinan handling kit.
Bilsteins felt great alone, springs made it so much better but more aggressive/rougher, probably have 250 miles so far and still need an alignment.
Thanks
      08-14-2020, 07:49 AM   #2
matteblue3er
238
Drives: Racecar
You may be able to use an adjustable spring perch but xi is suppose to have front rake
https://www.ebay.com/itm/Solo-Werks-....c100677.m4598
      08-26-2020, 11:08 AM   #3
Boosted12a
68
Drives: BMW 335i x
Did you install the spacers on top of the springs in the rear?
      08-26-2020, 03:03 PM   #4
ewicky
Drives: '07 335xi 4D AT
Dang that looks good. Why would you wanna raise it?
      08-26-2020, 04:40 PM   #5
apexxx6789
Drives: 335XI
Thank you for this info. BC racing also sells perches for $100.
I have not even purchased parts yet, but it’s on the to do list.
Reason for wanting to raise is I decided not to lower the car to preserve ride quality and just want it back to stockish, 1/2 inch higher, since the front is pretty high.
So far love the new suspension set up and stiffer springs are a must. Hoping to find someone with coils and see what their ride quality is like for future reference.
      09-06-2020, 07:12 PM   #6
apexxx6789
Drives: 335XI
Well perches are not going to work wth the Dinan springs, need to be flat. Who knows the spring rate? Lol
      09-08-2020, 11:01 PM   #7
Vivek.
1368
Drives: 335is coupe, e30 vert
Can you throw an extra spring pad on the top or bottom of the springs? Some dense rubber about 0.25" thick (loaded) should get you about 0.5" ride height increase
      09-21-2020, 01:30 PM   #8
stelvio
20
Drives: E91 335xi + E70 X5d
https://www.bimmerworld.com/Suspensi...pring-Pad.html
Vivek.1367.50
      10-12-2020, 11:36 AM   #9
avocet
252
Drives: 2007 328i 2011 X5d
Originally Posted by stelvio View Post
I used similar pads to these only trimmed to fit between the spring cup/mount and unibody. Worked perfectly to gain 1/2 or so more height.
