car shaking when i start it.
08-11-2020, 07:26 PM | #1 |
Rep 13
so i drove to my parents house which is a ten minute drive. nothing wrong on start up or during the drive. i stop at my parents for fifteen minutes get in the car and try to start it and nothing. had power and everything. thought it might be the starter so i went to auto zone bought a new starter and called a mobile mechanic to install the new starter. walla the car turns on after install, but when i got in it was shaking violently for 10 seconds and the idle was going down, after the ten seconds it would just stop shaking and idle would go back to normal. this happens everytime i was starting it up after the new starter which wasnt happening before. i called the mobile mechanic and told him, because im thinking there might be something loose when he was reinstalling it. he fought me on it telling me he put everything back properly. he put diagnostic obd and said that 3 oof my cylinders were misfiring. i dont understand how thats possible because it literally didnt do that till after the install. any advice would be helpful.
bmw 328i 09 85,000 miles. |
08-13-2020, 10:48 AM | #2 |
130
Rep 318
Bump, since this is falling off the front page....
Did the mechanic check the codes before installing the starter? The car may not have started due to a bad crankshaft sensor, which I had awhile ago. I think that could also cause the misfires, although it does seem odd that the car would not start, and after the starter replacement, it did start. Good luck! |
Mullerlicious1.00 pete.rex0.00 |
08-13-2020, 10:52 AM | #3 | ||
Rep 13
08-13-2020, 01:47 PM | #4 |
1917
Rep 13,109
By any chance did the accessory belt break before this happened?
Has this guy worked on this type of car before? Was he a mobile BMW mechanic? Did he put in a new manifold gasket and and make sure all the hoses were not broken. Unfortunately a lot of stuff has to come of an go back on properly and those hoses can be fragile. Last edited by ctuna; 08-13-2020 at 01:58 PM.. |
08-13-2020, 02:24 PM | #5 |
Rep 13
Nothing broke before it happened. The starter literally just died without warning. He was a bmw mobile mechanic. And no he did not replace any gaskets or hoses. Thanks for your input
08-13-2020, 04:24 PM | #7 |
Rep 13
He charged me 370 for the labor only. Took him an hour. I tried to go lower since I bought the starter myself but he wouldn't go for it and my car was in a bad spot that I couldn't leave for a couple of days.
08-13-2020, 04:41 PM | #9 | |
130
Rep 318
I have nothing against mobile mechanics, and used a locally-known BMW expert for my valve cover gasket. It started roughly for a week, until I saw the gasket was not seated correctly. He came back and redid it, no cost, and the car has run well for the past 2 years. People make mistakes. |
08-13-2020, 04:45 PM | #10 | |
2714
Rep 4,046
1) Did you observe WHAT he removed to access the Starter Motor? 2) Did he remove the INTAKE Manifold? 3) I understand that he did NOT replace any Hoses or Gaskets? 4) What specific codes were read, or what specific cylinders "misfired"? 5) Has your SES light come on during any rough running with "misfire" and then gone out after normal smooth idle returns? 6) Can you get Advance Auto, Autozone, etc. to read any codes NOW saved in the DME (Engine Control Module) Memory? Please report code numbers. 7) Does the Rough idle happen EVERY time you start the engine, no matter whether engine is cold, warm, or hot? 8) Have you tried disconnect the MAF Sensor Connector and starting the Engine to see if any difference? That WILL cause SES to light and save a Fault Code related to MAF Sensor signal in DME Memory, but if the cause of your Rough Idle is a vacuum leak, the idle should be noticeably BETTER. As others have suggested, the most likely cause of the Rough idle immediately after Startup is a vacuum leak due to air that has NOT been measured/ metered by the MAF Sensor entering the Engine/ Intake, causing Lean running. That CAN cause misfire codes and/or OTHER codes such as Bank 1 or Bank 2 Too Lean. With Answers to questions above, we can suggest "Next Steps". George |
Buug95917570.00 |
08-13-2020, 10:01 PM | #11 | ||
Rep 13
08-13-2020, 10:14 PM | #12 | ||
Rep 13
Did not replace any gaskets or hoses. He removed the fuel pump and everything underneath to access the starter. I can give you the codes Tom that I received from him after he did the diagnostic after installing the starter. Tom I'll attempt starting after disconnecting the sensor. Before that I will test first cold start. So far it would shake after every warm start but idle perfectly after ten seconds. There is a check engine light now after the starter was installed which was not their prior. I don't remember if it disappears after good idle. Will also check tom. I will also go to autozone and see what codes they bring up. |
08-14-2020, 05:01 AM | #13 |
17364
Rep 18,757
He did a starter on an 85,000-mile N52 in an E90 in an hour? The engine doesn't run correctly now? And the mechanic DOESN'T think he screwed something up?
He probably broke the CCV hose from the valve cover. Does the engine sound different when running? Have you simply checked to see if the oil fill cap is fully closed? If it was fully closed, then get the engine started and past the rough idle. Then open the oil fill cap and see if the idle changes. That test checks to see if there is a vacuum leak and the ECU is compensating for the leak. The illuminated SES icon is telling you there are codes present when the engine is running. It's possible some of the spark plugs are aged and beginning to fail. At 85,000 miles, do you know if they have been recently changed? The '09 N52 has a 100,000 mile spark plugs interval. It's possible some of the plugs are going early and it is just coincidental the starter died now. But if the SES light was not on before the starter repair, it's doubtful. I still don't believe a mobile mechanic can replace a starter on an N52 in an hour. Last edited by Efthreeoh; 08-14-2020 at 05:30 AM.. |
08-14-2020, 09:34 AM | #14 | |
Rep 13
08-14-2020, 10:05 AM | #16 | |
Rep 13
08-14-2020, 11:04 AM | #21 | ||
Rep 13
08-14-2020, 12:11 PM | #22 |
15
Rep 58
Those codes are for misfires on cylinders 1, 2, and 3 (the entire bank 1). My guess is he forgot to plug something in when reconnecting, like the throttle body (which I actually forgot too). Still, I'd expect more codes than just misfires. Hoping he didn't break something and cause a vacuum leak in the crankcase ventilation system or electrical connection to the fuel injectors. 1 hour was pretty quick to do this job, I'd say something was probably missed.
Tags |
328i car shaking on start up |
