Bimmerpost
4 Series
Technical Topics Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin What type and brand of fuel do you use?
      08-09-2020, 04:20 AM   #1
Aileron88
Drives: M340i
Hi all,
What fuel do you put in your M340i? I'm based in the UK and currently use Tesco Ultimate 99. Interested to hear what everyone else uses and if there is a noticeable difference in fuel types?
Cheers
      08-09-2020, 05:09 AM   #2
Ikester19
Ikester19's Avatar
Australia
2124
Drives: G20 M340ix; F30 328i msport
2018 330i LCI  [0.00]
2020 G20 M340ix  [0.00]
Originally Posted by Aileron88 View Post
Hi all,
Cheers
When I asked the service manager at my local dealer and he said to use the recommended 95 Ron stated on the fuel cap as that is what the engine is tuned for.
I use Shell 98 Ron here is Aus as I find it burns cleaner (less carbon build up on the exhaust) as compared to when I've used 95 Ron. Performance wise it feels slightly more responsive on 98 but that could just be placebo!
      08-09-2020, 06:45 AM   #3
Flamingi
Germany
531
Drives: M550d F11, 225xe U06
  [0.00]
I always try to get Aral Ultimate 102 (US 96 Octane). Has served me well in the past, no issues and most engines will produce a bit more power (especially with a tune). With an Aral membership it also costs the same as normal 98 fuel (Super Plus in Germany, US 93 Octane). For my Diesel only Shell offers a performance fuel, but in contrast to Ultimate 102 I haven't noticed a difference so I just get standard Diesel.
The members across the pond unfortuantely don't have the luxury of high performance fuel.
      08-09-2020, 10:35 AM   #4
Aero7000
Aero7000's Avatar
246
Drives: M340i DravitGrau / Cognac
Using Shell 91 V-Power 90% of the time, it is a recommended one.
Tried Costco 91 and honestly do not see much performance difference.
Also reading up on Costco quality, it is ethanol free and probably drawn from the same refinery.
I'm not 100% sure on Costco, and I do not drive as much due to work from home, price difference is not an issue at this time.
      08-09-2020, 01:33 PM   #5
sikotic
488
Drives: 2020 M340I
On the 4 series I just filled up wherever was near by. With the M340I I've been using Shell 91 V-Power the whole time.
      08-09-2020, 01:37 PM   #6
del82
102
Drives: BMW M340i xdrive
Shell V Power 99 RON UK
I think it makes a slight difference over time but mainly use it because it burns cleaner.
I know I'm being ripped off but hey.
Current: 2020 M340i
Past: M140i, Z4 35is
      08-09-2020, 05:23 PM   #7
SteveinArizona
Drives: BMW 530e
I use 91 octane, usually from Costco but sometimes from Shell. Always from a top tier supplier.
93 is not an option in Arizona. All the high test (how's that for an old term?) here are limited to 91 octane unless one gets racing fuel.
      08-09-2020, 07:50 PM   #8
NYC_340i
Drives: '20 M340i xDrive, '11 X3 28i
There's a Costco not even a mile from my house so that's where I fill up 90% of the time. It's the cheapest and has a Top Tier rating with the premium 93 I put in.
When I travel the preferences in order is:
1. Costco
2. Shell
3. Any other gas that's rated Top Tier.
I avoid Sunoco like the plague for some reason I get noticeably lower fuel economy after using their gas.
Current: 2020 M340xi
Previous: 2016 340xi
      08-09-2020, 10:44 PM   #9
marcin693ca
Drives: BMW 330i xDrive (g20)
I use 89 in US, the recommend either 89 or 91
      08-09-2020, 11:27 PM   #10
danahmedG20
danahmedG20's Avatar
Drives: 2020 BMW M340i xDrive
Sunoco 93 Octane does the trick for me.
Burns clean and rips hard
      08-10-2020, 12:32 AM   #11
xacoffeemx
33
Drives: 2017 320i, 2020 M340i
M340i RWD w/ Mission Performance Stage 2 here
4 gallons of e85 from 76
and the rest is 76's 91
Unfortunately stuck in California with crap gas.
chenry2355.50
      08-10-2020, 10:39 AM   #12
randybobandy
Rick James
randybobandy's Avatar
305
Exxon Mobil 93...I was using Sunoco 93 Ultra, but saw they dropped their standard as a "top tier fuel" due to COVID. Not sure if this makes a difference or not, but still seems to burn like a charm!
      10-25-2020, 01:16 AM   #13
G20Dan
Drives: 2020 M340ix
Is it OK to run unleaded 100 octane in these cars for track days?
      10-25-2020, 12:55 PM   #14
TheDudeMan
TheDudeMan's Avatar
Ukraine
252
Drives: 20' 330i & RX 350
      10-25-2020, 01:32 PM   #15
hamera
hamera's Avatar
United Kingdom
442
Drives: 320i M Sport (G20)
Shell V-Power 99
      11-12-2020, 01:43 AM   #16
plopez12808
17
Drives: 2020 M340i
Are you in Los Angeles? Where do you get your e85 from?
      11-23-2020, 01:32 AM   #17
MBM340
MBM340's Avatar
Drives: 2021 M340 RWD
2021 BMW M340i  [0.00]
Always either Shell V Power 93 or Exxon-Mobil 93 Supreme.
"Either get busy living, or get busy dying. That's GD right." - Red (Shawshank)
      11-23-2020, 01:35 AM   #18
MBM340
MBM340's Avatar
Dan, not an expert on our M340s as mine hasn't even arrived yet, but spent a great deal of time behind the wheel of various race cars on weekends. I don't see any reason why a higher octane fuel would be a problem in these cars. Most ECUs in modern day BMWs and the like can adjust for when the fuel is firing in the cylinders. Now if you went too far the other way the engine may not like it, but we used 100 octane race fuels in cars much less sophisticated than these with no issues...
VipinLJ1941.50
      11-23-2020, 06:43 AM   #19
todd92
170
Drives: 05 ZHP, 19 X5 xDrive40i
I use gasoline.
      11-23-2020, 03:06 PM   #20
greekcs
greekcs's Avatar
Drives: 2020 M340i xDrive
I usually go with Shell V-Power 93.
2003 11/02 Steel Gray Metallic on Red M3 - SMGII - VF570 - SUPERSPRINT - KW - BBS - CSL ROOF SOLD
2015 09/14 Alpine White on Red 435i xDrive MPPK - Expensive black vinyl with special lettering. SOLD
2020 12/19 Mineral Gray Metallic on Black Vinyl interior M340i xDrive
      11-23-2020, 03:25 PM   #21
Merami fan
めらみぽっぷ fan
Merami fan's Avatar
Drives: 2020 330i xDrive
Shell 93. Seems to be held in high regard. Bonus: the stations are never too busy and paying through the app is nice.
2020 330i xDrive in mineral white.
Username and profile picture in admiration of the goddess of treble, めらみぽっぷ (Meramipop).
https://www.youtube.com/watch?v=fQYWhQXOeQg
https://open.spotify.com/playlist/1w...1L3y6cmPEyGSoI
      11-23-2020, 10:00 PM   #22
VipinLJ
Petrolhead
VipinLJ's Avatar
Drives: ‘20 330i,‘16 X3,‘18 SQ5,‘17 A7
3.75 gallons E85 and the rest 93 octane fuel from Shell, BP or Costco.
Current:
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
g20
