08-06-2020, 11:42 AM | #1 |
50
Rep 198
Can someone please test your seats for me
Does your driver seat goes back to position after you use the button to lower/raise your rear seats either to allow 3rd roll passenger in or do max luggage/passenger?
My driver side leans forward to put the 2nd row in position but when all said and done, it doesn't go back all the way. Additionally, once I squeeze myself into the car and start the engine I have to press my memory seat button in order for the seats to go back to position. |
08-06-2020, 11:59 AM | #2 |
1909
Rep 2,007
Drives: 2022 i4 M50
I deal with this on a weekly basis when dropping off/picking up the kids. I'm pretty sure I've found that if I do ANYTHING (open/close a door, take off/put on a seat belt, etc.) on that side of the car, it interrupts the process and the front seat does not go back to position automatically.
They are old enough to get in/our of the car on their own and I'm a relatively small guy, so my typical process is to press the button on the driver's door to prep the back for them, let myself get a bit uncomfortable, then have them get in the back. I should add that I have captains chairs, so once the seat is prepped, they are just manually pulling the release on the back of their chair to tilt the back forward. As long as they don't close the door or put on their seat belt before the seats stop moving, I'm typically released from my cramped position automatically.
Current: 2022 i4 M50 | 2022 G07 X7
Gone: 2020 F92 M8 | 2020 G07 X7 | 2018 F80 M3 | 2017 F15 X5 | 2016 F16 X6 | 2015 F36 4 series GC |
Osheatwo206.50 |
08-06-2020, 12:26 PM | #3 |
50
Rep 198
I don't have captain chairs but here's an example.
Without anyone monkeying around with the seats or the belts, from the trunk, if I press max cargo, (or any other seat adjustments) driver and passenger seats move forward, rear seats would do its thing, front passenger seat would move back to the "last" position, driver seats would move back just a little but not last position. Squeeze in the driver seats and turn on the car, technically at this point the seats should move back to the position that matchs the driver profile. BMW just told me that this is normal, question is, why does the passenger seat goes to position but not the driver? Did somebody F up on the programming? FWIW: My seat frame was recently replace because of this, previously it would just move back a little, since they try to fix it, it moved back maybe 2 additional inches. |
08-06-2020, 04:29 PM | #4 |
1311
Rep 1,636
08-06-2020, 04:34 PM | #5 |
50
Rep 198
Only one key is ever used for this car and yes the key is synced to driver 1 driver 2 is not setup, my wife has never driven the car without me in it so there was never a need.
08-06-2020, 06:19 PM | #6 | |
1909
Rep 2,007
Drives: 2022 i4 M50
08-06-2020, 06:21 PM | #7 |
50
Rep 198
08-06-2020, 07:30 PM | #8 |
87
Rep 217
I have noticed the same. Driver Seat in the front does not move back automatically. Also 2nd row does not move automatically to original position either. Although the second row bench does move, it stays in a forward position with least amount of leg room , then you need to manually move the seat back to get more leg room.
08-06-2020, 07:46 PM | #9 | |
50
Rep 198
I think this is a software issue |
08-06-2020, 07:55 PM | #10 | |
82
Rep 235
08-06-2020, 08:42 PM | #11 | |
805
Rep 1,790
08-06-2020, 10:50 PM | #12 |
The Centurion
137
Rep 451
I had this issue with the bench seat and solved it with a work around
I'll double back but if I recall it's to do with profile or seat a memory. I'll check and confirm
From the East to the West through the rest of the World
08-08-2020, 01:18 AM | #13 |
Paul Tattoo
190
Rep 482
For all this is worth: When I move the third row seats with the button in the trunk, the drivers seat will move all the way up and then just stay there. But the worse part is that the memory button for the drivers seat will not work. I am told to select driver profile. When I do, it says my profile is already active. I then move the seat back so I can fit and just readjust the seat. Start to drive off and after a few minutes re-select the driver profile and things go back to normal.
I assume it's a shitty glitch.
Received on 12/28/2023: 2024 X7 XDrive 40i Obsidian Black, Coffee Vernasca Leather, M SPORT, EXECUTIVE, DYNAMIC, ASSISTANCE PRO PKG, LUX SEATING, COLD WEATHER, PARK ASSIST, Ambient Air, Shadowline Trim,
Harman Kardon, Trailer Hitch. |
08-08-2020, 03:08 PM | #14 | |
50
Rep 198
If the passenger seat doesn't move back to position and the driver does, I'd probably be less aggrevated. |
08-08-2020, 08:55 PM | #15 |
1311
Rep 1,636
It’s not that it looks cool, it is far more comfortable for second row passengers. My youngest is nine years old and we don’t need a car seat. We are a family of 6 and don’t need a 7th seat. If we wanted a cargo hauling SUV we would just go buy one; we wouldn’t try to convert a $90,000 luxury car into a U-Haul.
unfoundnemo1909.00 |
08-11-2020, 03:11 PM | #16 | |
77
Rep 205
We have three kids 4,8,&11 and most of the time our 3rd row is down. When we need the extra seat we more often than not just fold the middle seat back flat and let the kids climb back in keeping the car in this 6 seat config. I really find the whole seat movement thing annoying. Most of the time we do fold the middle seat the front seat back is nowhere near the middle row but the front seat always moves up. It's overly cautious. |
09-16-2020, 08:06 AM | #17 | |
34
Rep 157
Drives: X7_M50d(2020), X5_30d(2015)
I'm wondering, does it work for anybody as it should? (at least according to common sense) |
09-17-2020, 11:13 PM | #18 |
815
Rep 1,078
Drives: Lots of BMWs
Garage List 2018 M4 Vert [0.00]
2006 Z4M Roadster [0.00] 1995 540i [0.00] 2008 BMW M5 [0.00] 2019 i3 Rex [0.00] 2021 X7 40i MSport [0.00] |
I just found this out with the second row. Kids are demoted to the 3rd row and most of the time no body will be in the second row (captain), so I want the second row all the way forward, but when having the seat do its thing to let them in the 3rd row the 2nd row will go to the default spacing, so have to move the second row seat forward again each time, very annoying.
2008 M5 6spd, 1995 540i 6spd
2018 M4 Vert Comp, 2019 i3 120ah REX 2021 X7 40i MSport, 2006 Z4M 6spd |
09-20-2020, 11:17 AM | #19 |
The Centurion
137
Rep 451
I just checked and confirmed
When using the buttons in the second row. To default move or flat. The driver seat does go back to its saved settings. Now when doing anything from the trunk. It didn't, but pressing the memory button brings it back. Worth mentioning that my 3rd is always flat and not used. Issue was existing at all times before software update to 07.2020.30 I'm assuming it's a glitch they are addressing in the software
09-20-2020, 03:44 PM | #20 | |
111
Rep 376
12-13-2020, 05:01 PM | #21 |
805
Rep 1,790
I know this thread is a few months old but has this issue been resolved on iStep version 11/2020.xx? I'm on 07/2020.54 and this is still an issue.
Every time I fold down the 2nd row seat backs the drivers seat never returns to the position it was in before I folded down or moved the second row seats for 3rd row access. I'm guessing this is another low priority issue for BMW since it still exists after multiple iStep updates. Come on BMW! Get it together. |
12-13-2020, 06:56 PM | #22 | |
37
Rep 85
Drives: 2021 BMW X7 40i
