BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > F20 LCI 2015 - Squeaking sound problem coming from inside the vehicle
      08-04-2020, 02:54 PM   #1
rohe
rohe's Avatar
Drives: BMW F20 LCI
Angry F20 LCI 2015 - Squeaking sound problem coming from inside the vehicle
Squeaking sound problem coming from inside the vehicle. Door wicks are cleaned and oiled. Shock absorbers were checked. But the problem continues.
VIDEO LINK
What do you think the problem is from?
Thank you very much for your help..
VIDEO LINK
      08-08-2020, 03:17 PM   #2
rohe
rohe's Avatar
Drives: BMW F20 LCI
The problem still continues.
Not the shock absorber sound.
It's not a door seal.
It is not a filter cover.
Not a torpedo cover either.
      08-10-2020, 08:13 AM   #3
rohe
rohe's Avatar
Drives: BMW F20 LCI
Today I discovered something new. With the steering wheel facing left, the sound is cut off even if the road is rough.
      08-10-2020, 11:03 AM   #4
rohe
rohe's Avatar
Drives: BMW F20 LCI
Also, the days I wash my car, the sound does not come for 6-7 hours.
      08-10-2020, 05:54 PM   #5
No one
1045
Drives: F21 118i
Well, I just had a hydrobearing (#7) replaced along with the regular service lately. There had been no sound/symptom but they dug it so meticulously looking to suck extra money it was painful to watch. They (an official BMW service) told me it wasn't necessary to replace the other one (apparently upcoming) as well and do the wheel angles correction.
      09-22-2020, 09:54 AM   #6
super135
Drives: M135i
Hi
exact same sound on my M135i coming from the bottom right over bumpy roads, like styrofoam rub. I changed the engine mounts and retighten the subframe, and it went away for a while ! for 1 month absolutely quiet ! May be caused by engine rocking. Have that checked. I eliminated suspension because it could happen stationary on the brakes but with slight throttle. My mechanic pried the engine while on a hoist with a bar and it creaked abit. Good luck and pls report back ! Lately its coming back again .. SIGH!
      12-16-2020, 04:46 AM   #7
maxxsp
Drives: BMW E46 M3, BMW F20 120i
Does your car have the teflon tape fitted along the top where the door seals touch the body? That solved the issue for me.
      01-04-2021, 12:44 PM   #8
Njave
Upstairs drinking coffe
Njave's Avatar
Croatia
25
Drives: BMW F21 118d
Did you check the foam added to each door (right where the side mirrors are attached) maybe? I had a similar squeak noise coming (albeit when closing/opening the door) in that area. Might be worth taking a look there.
      01-29-2021, 03:13 PM   #9
rohe
rohe's Avatar
Drives: BMW F20 LCI
Hi everyone,
My problem is still not resolved. I went to many BMW Services but they could not find the source of the problem.
The sound stops in rainy weather and when I just wash my vehicle. It comes back in dry weather. What could be something that cuts off when it gets wet?
      01-30-2021, 01:28 AM   #10
F20_M135i
France
101
Drives: BMW F20 M140i Xdrive
your video of your problem is no longer available, it's hard to get an idea of your problem
      01-30-2021, 02:31 AM   #11
rohe
rohe's Avatar
Drives: BMW F20 LCI
Sorry, new link added.
      01-30-2021, 06:55 AM   #12
F20_M135i
France
101
Wait for the noise to occur again (and for it to be dry outside) then lean under your car at the front right and spray a large quantity of WD40 (or any other lubricant) on the 4 points of attach the parts in the diagram circled below, and go for a walk to check.
      01-30-2021, 11:17 AM   #13
rohe
rohe's Avatar
Drives: BMW F20 LCI
thank you so much. I ordered WD40. I will definitely try it as soon as it comes!
      01-30-2021, 11:38 AM   #14
F20_M135i
France
101
You're welcome !
You should ONLY put it (WD40) on the attachment or anchor points of the drawing.
This will make it possible to eliminate some causes (temporarily)
To do this correctly, you will need to lie down, passing under the front passenger door to access it.
See you soon
      01-30-2021, 11:39 AM   #15
rohe
rohe's Avatar
Drives: BMW F20 LCI
You're welcome !
See you soon
Do parts need to be changed for a permanent solution?
      01-30-2021, 12:09 PM   #16
F20_M135i
France
101
You have to wait for the state (of the video noise) to pronounce this
      01-30-2021, 10:29 PM   #17
No one
1045
Drives: F21 118i
As mere water kills the sound you should be able to use it to isolate the sound source just as well.
