BMW X5
      07-30-2020, 10:37 PM   #1
IND-Distribution
BMW obsessed
IND-Distribution's Avatar
9575
Drives: G82 M4 / G87 M2
IND | BMW M Performance F95 X5M / F96 X6M Carbon Mirror Cap Set Install Guide
Tools Required:
  • Pry Tool
  • Painter's Tape
STEP 1: Place a layer of painter’s tape against the mirror base to prevent any damage during the mirror cap removal process.
STEP 2: Wedge a pry tool inside the channel between the mirror cap and base. Twist the pry tool along the channel at multiple points to help pop the mirror cap away from the base.
STEP 3: Line the BMW M Performance carbon cap up with the mirror base. Once properly in position, use uniform pressure to snap the carbon cap into place. Repeat this procedure on the other side.
IND DISTRIBUTION | 866-963-4520 • INSTAGRAM • YOUTUBE • FACEBOOK • FLICKR
      07-30-2020, 10:44 PM   #2
saintsinc
saintsinc's Avatar
Drives: BMW X5 M50i
Originally Posted by IND-Distribution View Post
Tools Required:
  • Pry Tool
  • Painter's Tape
Is this suitable for M50i?
      07-31-2020, 12:33 PM   #3
IND-Distribution
BMW obsessed
9575
The install process is the same for the G0x, yes.
      07-31-2020, 01:24 PM   #4
saintsinc
saintsinc's Avatar
Drives: BMW X5 M50i
Do you need to change the outer ring as well ?
      07-31-2020, 03:05 PM   #5
saintsinc
saintsinc's Avatar
Drives: BMW X5 M50i
Please send a link to purchase this thanks
      07-31-2020, 05:41 PM   #6
IND-Distribution
BMW obsessed
9575
PM Sent.
      04-05-2021, 10:34 PM   #7
nZtiZia
nZtiZia's Avatar
Drives: eVeRyOnE mAD!
the above post didn't really clarify it for me. can these replace the mirror caps on the G05 without issue?
      04-06-2021, 08:04 AM   #8
IND-Distribution
BMW obsessed
9575
These will only fit the F95 X5M, not the G05 X5 as the housings are different.
nZtiZia4635.50
      04-16-2021, 08:40 PM   #9
BobsM3Coupe
BobsM3Coupe's Avatar
Drives: X5MC
Do these also fit the F97/98? Someone said they use the same mirrors as the F95/96.
      01-10-2022, 08:04 AM   #10
Toofdocta
Drives: G05
Are you still selling these CF mirror caps for X6M? If so, how much for the pair?
      01-11-2022, 09:15 AM   #11
IND-Distribution
BMW obsessed
9575
Yes they fit F97/8 and F95/6.
PM Sent.
xbimmers
