07-26-2020, 02:33 PM | #1 |
28
Rep 53
228i Strange noises after replacing clutch.
I have a 2016 228i with a 6MT that I've had since January. I bought it hoping the low mileage of 16k meant 'gently used' but it quickly turned out it meant 'incompetently used' because the clutch failed almost immediately forcing a replacement of both the clutch and the flywheel which I had done by the dealership down the street. It's been a week and now I'm hearing this very strange creaking/squeaking/grinding noise.
Noise occurs when accelerating briskly in medium gears, e.g put your foot down at 40mph in third gear. Sound rises in pitch and goes away when the revs get above 4-5k. It also sounds like it's coming from behind me but I can't tell if it's far enough back to be the diff or something. I'm going to give the dealership a call tomorrow morning regardless but after almost two hundred thousand miles in MT cars this is the first time I've had a clutch fail, as well as my first BMW, so I'm not sure what's normal or how to know if the dealership is feeding me a line of crap. Any ideas? |
07-26-2020, 03:04 PM | #2 |
3079
Rep 5,578
is the clutch fully engaged and the pedal completely released when you hear the noise - do you hear any noise when you have the car in neutral ( clutch pedal fully depressed and clutch pedal fully released ) and rev the engine into the range where the noise occurs ?
07-26-2020, 03:10 PM | #3 | |
28
Rep 53
I'm worried this is another abused part that wasn't getting enough torque to cause problems until the bad clutch got replaced. |
07-26-2020, 08:09 PM | #4 | |
3079
Rep 5,578
it might just be a bolt that wasn't fully tightened some people ride the clutch and so the clutch friction surfaces go bad quickly and really its not that abusive. Im not that familiar with the 2 -series but sometimes with flex disc on driveshaft and dropping exhaust for a clutch change it's easy to get a small item that needs to be handled on follow-up. |
07-28-2020, 12:01 PM | #5 | |
28
Rep 53
If that IS what it is, it's going to leave me a bit concerned with the attention to detail at that shop though, and I may not take my car there anymore. |
07-28-2020, 02:07 PM | #7 | |
3079
Rep 5,578
A loose bolt on a heat shield is very minor. These days a test drive by a mechanic after a repair sometimes has customers complaining. So shops try to get cars back to customers as soon as possible with fewest amount of miles accumulated. And there are so many minor bolts that get tightened on a job like these. If it is just a loose bolt, I personally wouldn’t be concerned about quality of work. |
07-28-2020, 09:14 PM | #8 | |
28
Rep 53
As far as the BMW goes, it turns out instead of a loose bolt, it was a broken plastic clip that holds the parking brake line in place, and that was rubbing on the driveshaft under acceleration. I mean, mostly I'm just happy it's not the diff or something serious, but what's funny is that he had to ORDER new clips, so it's going to wind up in the shop for two days just for that. |
