07-10-2020, 06:06 PM | #1 |
1977
Rep 4,225
Steering wheel fails to drop down to preselected position
Today marks the second time the steering wheel did not drop down to my preselected position based on my settings. And it would not move at all with the button on the side of the steering wheel that controls position. The first time this happened was a few weeks ago. After sitting it did it usual movement.
Has this happened to anyone else? I check the other boards including the present 5-series and it is a known issue. But, I didn't see much discussion surprisingly. |
07-11-2020, 02:26 AM | #2 |
1652
Rep 2,402
Yep, had this happen. I hit the memory button on the door when this happens and puts it to where it should be.
This and the whole seat thing.....where sometimes I'll start the car and won't go to my normal seat position and side mirrors will be all messed up. I suspect they are related somehow. It happens very rarely.
2022 M8 Comp GC, 2021 AMG GT53, 2022 X5M Competition, 2021 X7 40i, 2019 M5, 2018 M550I, 2017 Audi Q7, 2014 M6 GC, 2013 Mercedes CLS550, 2011 750LI, 2008 M6 Cabrio, 2008 Porsche Cayenne S, 2004 Mercedes SL55 AMG, 2003 Mercedes SL500, 2000 Mercedes CL500, 1993 Lexus SC400, 1989 525i, 1985 318i
gblansten1976.50 |
07-11-2020, 07:02 AM | #3 | |
252
Rep 660
gblansten1976.50 |
07-11-2020, 08:47 AM | #4 | |
1977
Rep 4,225
07-27-2020, 05:53 PM | #6 |
1977
Rep 4,225
Have an appointment for next Monday. The steering wheel fails to work every single day the car is left out on the sun. Works the next morning on the way to work. I'm going to need a new steering wheel column.
07-28-2020, 12:00 PM | #7 |
317
Rep 516
Happens with my seat position periodically.
If you're in gear, you need repeatedly press and hold the memory button. If you're not in gear, you can press the memory button once. |
08-03-2020, 09:06 AM | #8 |
1977
Rep 4,225
Just an update for anyone searching for this issue later.
Just took the car into the dealer. They found fault codes and did a reset. Hopefully fixed. If this recurs suspect I will need a new steering column mechanism. |
wesleyan921408.00 Jamesmick131.00 |
03-24-2021, 03:32 PM | #9 |
Grand Duke
1540
Rep 1,114
Drives: 2023 M4CSL
Did you ever get this fixed? My car is doing the same. I brought it in and they updated the software which did nothing. I'm taking it back Monday, but just curious what your outcome was.
2023 M4CSL
2005 Lotus Elise |
03-24-2021, 04:08 PM | #10 |
1977
Rep 4,225
It only happened when the car was in the sun during the summer. So it seemed heat related. It finally stopped in the fall and I held off on getting major work done to the steering column. It has not happened a single time since the end of summer 2020.
03-24-2021, 04:16 PM | #11 |
158
Rep 308
My UK spec 2019 comp did same today
The steering wheel did not drop down to driving position and the side mirrors were out of whack. I could still adjust wheel and mirrors with the buttons. I suspect it's cos I started fiddling with the idrive before everything set, and it skipped a few instructions on bootup. I usually let everything boot up before fiddling as these modern cars are like waking up a computer from sleep or hibernate...you want to leave them to complete the bootup process really before trying to get it to do other stuff |
03-24-2021, 04:24 PM | #12 | |
1977
Rep 4,225
03-24-2021, 08:09 PM | #13 | ||
Grand Duke
1540
Rep 1,114
Drives: 2023 M4CSL
2023 M4CSL
2005 Lotus Elise |
gblansten1976.50 |
03-25-2021, 01:28 PM | #14 | |
838
Rep 478
Next day worked fine after being parked back in my garage over night and has never happened again since. Glad to hear I’m not alone with this one. |
gblansten1976.50 |
03-26-2021, 02:04 AM | #15 |
210
Rep 323
Drives: BMW X5 G05 30d/BMW M5 F90 Comp
We had this issue.
It was fixed under warranty. Turned out to be a burnt out module inside the steering column. |
carseatsm5837.50 |
03-26-2021, 08:12 PM | #16 |
1977
Rep 4,225
03-26-2021, 09:30 PM | #17 | |
75
Rep 76
MNoob1539.50 |
03-30-2021, 11:19 AM | #18 | |||
Grand Duke
1540
Rep 1,114
Drives: 2023 M4CSL
2023 M4CSL
2005 Lotus Elise |
05-28-2021, 10:42 AM | #20 |
158
Rep 308
Update:
Mine now does not park in the up position when engine is switched off. The steering wheel is in the correct position for me and driving and still moves with the buttons, but may have to take to dealer incase there is an issue hiding in the electronics for the future |
06-01-2021, 04:16 AM | #21 | |
158
Rep 308
As mine was still responding to the adjustment stick, I used them to make sure it went through it's full range of movement i.e. in/out and up/down. I then did a hard reboot of systems by pressing the mute button for 30secs. Seems to have done the trick, all is working again |
gblansten1976.50 |
