BMW 2-Series Gran Coupe
BMW 2 Series Gran Coupe Forum (F44) BMW 2 Series Gran Coupe (F44) General Discussion
      07-10-2020, 02:43 PM   #1
mikeyb74
mikeyb74's Avatar
Drives: G20 330ix M Sport
Retrofitting Wireless Charging
Has anyone retrofitted the genuine wireless charging in their F44? I see everyone with G20 3 series are retrofitting from the NFC module to the wireless charging module. The only coding is for the don't forget phone. They are saying it is plug and play were the NFC will still work.
Appreciate 2
      07-11-2020, 06:24 AM   #2
sansagara
F44 Fan
sansagara's Avatar
Belgium
Drives: BMW F44
Good question. I'm also interested, as my lease F44 did not come with the charger. It's a must for wireless car play! I wonder how easily it is to install, though... and if i must take it to the dealership for them to do it.
Gregory12.50
      07-11-2020, 06:25 PM   #3
BlownLSX
BlownLSX's Avatar
213
Drives: C6Z, X3MC
There is most likely a retrofit for adding it later as BCM is the same in across all models. It will require reprogramming if it is possible. However it might not have the harness plug. Won't know until you take it apart.
      02-20-2021, 08:15 AM   #4
maxyeo
maxyeo's Avatar
Singapore
Drives: 218i Gran Coupe M-Sport F44
Mine came with with wireless charging but redundant because my phone couldn't fit in .......
      02-20-2021, 09:07 AM   #5
Kothar
175
Drives: 20 m235i gran coupe
Yeah never use it as my s20 ultra too big!
      03-16-2021, 03:25 PM   #6
Murat Aydinoglu
Drives: E90 328 , 2012 e93 , 2016 f36
I had the phone not fitting issue so i removed the holders they are clip on. I am now just placing the phone there...
      03-17-2021, 03:18 PM   #7
FalconVFR
Drives: 2020 M235i, 2022 Ram TRX
Following. Just got our M235i, but doesn't have the wireless charging either.
      03-31-2021, 04:51 PM   #8
ScottC25
ScottC25's Avatar
United Kingdom
110
Drives: M4 Competition xDrive
Any progress on this? Be interested to know if it is doable, and how much work is involved?
      04-14-2021, 11:56 AM   #9
ScottC25
ScottC25's Avatar
United Kingdom
110
Part arrived today from Germany.
took a gamble on how to fit it by using more brute force than I wanted to, but absolute piece of cake, took me about a couple of minutes.
Wireless charging now in place, not fussed about getting the warning coded in, won't need it.
      04-14-2021, 11:58 AM   #10
FalconVFR
Nice!! So you just swapped the part, and wireless charging works?
What's the part number you ordered?
      04-14-2021, 12:48 PM   #11
AlpineAl27
AlpineAl27's Avatar
Drives: 2023 BMW 330e Xdrive
Nice!! Mines on order, how did you remove the NFC module?
ScottC25109.50
      04-14-2021, 01:31 PM   #12
ScottC25
ScottC25's Avatar
United Kingdom
110
Basically, once you take the removable lip off it's easy.
I just used long nosed pliers to pull on the part that the removable lip attaches to.
Did this on both sides, and the front of the existing one came off.
There were then plenty of places on what's underneath to grip with the pliers to pull it straight out.
Take the plug out the back, plug it into the new one and that's it.
I tested that it worked before pushing it fully back into place.
Someone posted a link on here for a guy in Germany selling them on eBay.
Have a good look as he has them advertised at different prices.
Appreciate 2
      12-30-2021, 03:16 PM   #13
M4R10s
Drives: f44
Folks, could you please let me know if you were able to use BMW digital key before retrofit?
My BMW digital keys has been removed from my setup and I'm wonder if I will add this wireless charger it will automatically added bmw digital key feature?
How complicated is connecting this part?
      01-06-2022, 05:38 AM   #14
M4R10s
Drives: f44
Has anyone added a wireless charger to their car? My car was produced without wireless charging.
I saw that is is possible to buy an OEM wireless tray (5A0E551) but I am not sure if the car that did not have this tray will have a bundle of cables to mount it?
Additionally, anyone knows if it possible retrofit of BMW DIGITAL KEY? My car was also produced without that key with information „32Z ENTFALL BMW DIGITAL KEY”. The car has an NFC handle on the driver's side.
I wonder if I add a wireless charging tray it will help with the bwm digital key or this needs to be activated on bmw connected drive servers?
      01-30-2022, 12:53 PM   #15
MugatuJag
17
Drives: 2022 BMW 228I XDrive GC
I’m wondering the same thing, I have a 2022 that has the exact same note on the build sheet, I really hope this form gets a little more active, I want to be a contributing member👌
      02-25-2022, 05:02 PM   #16
Tyr03
Drives: BMW 220iA Gran coupe
I can confirm the F40 Wireless charger totally fits in, bolt on exactly as described here.
I have also ordered mine online from a German seller.
      02-25-2022, 08:06 PM   #17
MugatuJag
17
Hey there if I may ask how much did you pay? Also do you have the NFC on your door? I have NFC on my door handle, and my car was supposed to be equipped with the digital key but it was removed due to the chip shortage. I’m thinking to buy an OEM wireless charger and was hoping I could have a friend help me code a digital key in����
      03-03-2022, 12:57 PM   #18
jettie1767
142
Drives: '23 BMW i7 xdrive60
Can someone message me on parts needed and supplier?
'23 BMW i7 xdrive60 - Frozen Deep Grey
'22 BMW 228xi Gran Coupe - Phytonic Blue
      04-12-2022, 02:37 PM   #19
Tyr03
Here is the link to the one I bought
https://www.befr.ebay.be/itm/265372079691
      06-07-2022, 11:44 AM   #20
Notleks24
Notleks24's Avatar
United Kingdom
Drives: BMW 128ti
Does anyone know if when retrofit of the wireless charging unit on the F40 requires coding? Or is it simply plug and play.
Thanks
      06-07-2022, 02:41 PM   #21
cukeuk
cukeuk's Avatar
142
Drives: Series 2 GC M235i xDrive
Post #9 suggests only the phone still in place warning would need coding?
      07-01-2022, 08:57 PM   #22
Derik_472685
Drives: BMW M235i
M235 Wireless Charger Mod
I had the issue where my S21 Ultra did not properly fit and the wireless charging was unreliable in a 21` M235i. Here are some images to help understand the parts and assembly/disasembly.
bmw
