F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > M2 brakes on a 340i work?
ARMA SPEED
      07-09-2020, 05:36 AM   #1
misguided_will
misguided_will's Avatar
Australia
57
Drives: 2018 BMW 340i M Sport
Hi all
Per title would a set of m2 brakes bolt right on a f30 340i or would knuckles need to be changed?
Thanks
2018 F30 BMW 340i M Sport
Injen EVO intake, OEM 437m rims, Catted VRSF dp, Magnaflow catback, Activ8 piggyback, Pedalbox.
      07-27-2020, 10:36 PM   #2
orangepeelforest
orangepeelforest's Avatar
Drives: '16 340i F30
2016 340i  [0.00]
I am pretty confident they will fit but I believe the 2 series has smaller pistons in the rear calipers. Check realoem.com before you buy.
'16 340i M-Sport F30 Estoril blue, Oyster, Bootmod3, CTS high flow cat, CTS intake
Sold:'07 335i E90 Montego Blue on black leather, Navi, premium, sirius, sport pkg, CA, logic7
Sold: '07 328i E92, SG, Saddle Brown, Gray Poplar, ZSP, CA, Heated Seats, BMW Performance Exhaust, BMW performance SSK, Valentine1, european delivery - Military Sales
      07-27-2020, 11:42 PM   #3
Gen13 F36
Gen13 F36's Avatar
Drives: 428i Gran Coupe
The calipers will fit you need to buy the rotor for the F30.
      07-28-2020, 03:17 PM   #4
Logicoeur
Logicoeur's Avatar
993
Drives: F30 335i xDrive
Yes all of the M2 calipers will fit, even the 400mm fronts from CS. Again m2,3,4 all use the same brembo calipers as our F30 35/40i get in mperformance/msport 370/345.
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
      07-29-2020, 06:13 PM   #5
blau3er
1147
Drives: F31 30d
The 6 pot calipers from the M2 Comp / CS will not fit on the F3x hubs - the OEM brackets foul on the F3x knuckle. You would need custom brackets to suit F3x to get it to work.
Also, if the OP is wanting to bolt on an full F87 M2 4 pot 380mm front / 2 pot 370mm rear brake set up - then no, it won't fit.
The calipers, as you say, are the same, but rotor fitment is different as the F3x is designed to use 370/345 and trying to put 380/370 rotors onto a F3x will not work.
      07-29-2020, 06:28 PM   #6
Logicoeur
Logicoeur's Avatar
993
Oh yes correct! There is a bracket needed just like the m5 calipers which we can use with the M2 CS rotors. Could the f10 and m2 cs use the same caliper?
      07-30-2020, 06:24 AM   #7
blau3er
1147
Drives: F31 30d
The M2 Comp / CS use the same caliper as the F8x CCB, which was a slightly higher mounting point on the caliper body - therefore meaning the brackets that I had made for my F31 to use F10 M5 6 pots / 400mm M2 Comp rotors would not work with either the gold CCB calipers or the silver M2 Comp calipers.
It would need adjusting to have height removed from the bracket to accommodate the extra height in the caliper.
f30post
