BMW M5 F90 (2018+) General Forums Regional Forums UK    Tyre Pressures
      07-08-2020, 11:21 AM   #1
Mark6147
England
10
Drives: F90 M5
Tyre Pressures
All
Just had to replace a front tyre for a puncture, very annoying when loads of tread left!
BMW have reset the tyre pressure monitoring system for the 20" inch tyres and it is recommending 2.8 / 2.9 bar for the front / rear.
This compares to the plate on the drivers door which suggests 2.4 / 2.5 for the front / rear? I usually follow the plate as with all cars.
What do other people do? Appreciate any assistance.
Thanks
Mark
      07-08-2020, 05:11 PM   #2
DannyA
United Kingdom
143
Drives: C8 RS6
Quite a big diff! - I would go with the door card.
      07-09-2020, 03:24 AM   #3
Ian335xd
United Kingdom
35
Drives: BMW F90 M5 2019
Originally Posted by Mark6147 View Post
All
Thanks
Mark
It should 2.4/2.5 and you will need a software update as the idrive was set incorrectly from the factory and is a common problem. You may find if you put the correct pressures in the car the idrive will tell you the pressures are too low and keep bringing a warning up.
      07-09-2020, 05:33 AM   #4
Mark6147
England
10
Drives: F90 M5
Thanks Ian!
      12-14-2020, 03:31 AM   #5
kljw
United Kingdom
10
Drives: BMW F90 M5
Mark
Ignore the door card. I had the same issue, two different dealers have the same reason, the card pressures are for std cars, not the M5.
Also made a call to BMW uk, who also gave the same answer.
Once I had increased mine, better handing and a better fuel return.
If you choose to use the settings on the door card, ensure the pressures are set when cold, and then do the reset so the car knows what the base setting is.
At the end of the day, it's your call, but can i suggest you check as I did.
Keith
      12-14-2020, 05:38 PM   #6
Maxlude
United Kingdom
158
Drives: E90 330D_SE_Man, F90_M5C
If you have MDrivers pack then idrive will want the 2.8/2.9 bar which is 40/42psi. Else it should be around 32/34psi as per door card. There was a bug in idrive that wants 2.8/2.9 bar even if you don't have MDrivers pack. A software update will sort it.
Search this Thread:
Advanced Search
