Exhaust flap plug in help
07-07-2020, 07:03 PM | #1 |
12
Rep 38
I heard about unplugging something in my trunk to keep my exhaust flap open on my e90 328i but can’t find any info online of how to get to it or where it’s at exactly. Can anyone point me in the right direction?
07-07-2020, 07:49 PM | #3 |
12
Rep 38
07-08-2020, 10:30 AM | #4 |
eBay Special
3079
Rep 3,031
Drives: E90 330xi
Yep 330s have them. You can disconnect the vacuum pump behind the drivers (US) taillight. Open the trunk, open the taillight cover, and look down and to the right a little bit. You should see a small connection and that's the one you want to pull.
Common sense is a flower that does not bloom in everyone's garden
07-08-2020, 02:27 PM | #5 |
12
Rep 38
I don’t see a second connector unless it’s really far in there. Just seeing the tail light/plug ins for that but not anything else just metal lol
07-08-2020, 02:37 PM | #6 | |
eBay Special
3079
Rep 3,031
Drives: E90 330xi
If you don't see a valve (which if yours is a 328 I doubt you have one) then you're out of luck for that mod
07-08-2020, 02:39 PM | #7 |
3031
Rep 1,811
Unless you put on a 330i muffler you don't have one. These cars are quiet in stock form, with or without the valve.
Hunt down an actual performance exhaust or search performance exhaust mod DIY to mimic the sound. It's probably the best sound on these N52s. That's my opinion anyways. |
07-08-2020, 03:06 PM | #8 |
36
Rep 206
IMHO muffler deletes are pretty annoying to hear from the outside. Maybe you could do a resonator delete, if not purchasing a performance muffler to enhance the sound. It does not need to be anything fancy, just something to open it up a bit.
07-08-2020, 04:24 PM | #9 | |
eBay Special
3079
Rep 3,031
Drives: E90 330xi
I can't remember the reason why BMW didn't use engine vacuum like any other car
07-09-2020, 03:17 PM | #10 | |
12
Rep 38
What do you think about this one? MagnaFlow 12148 Exhaust Muffler https://www.amazon.com/dp/B000CCDNU0/ref=cm_sw_r_cp_api_i_XR3bFbZSEZEA5 |
07-09-2020, 06:22 PM | #11 | |
36
Rep 206
07-09-2020, 10:05 PM | #12 |
eBay Special
3079
Rep 3,031
Drives: E90 330xi
Read the reviews and most of them seem to be people with N52s. They all seem to like it.
07-09-2020, 10:38 PM | #14 |
3973
Rep 7,215
But why? It's only closed below 20kph (12mph). It's going to make almost zero difference in sound except when you are stopped - and probably, it improves torque from a dead stop, so forcing it open is likely slower. Unless you want to be annoying and obnoxious, which I guess the muffler delete crowd is going for anyway..
07-09-2020, 10:54 PM | #15 | |
eBay Special
3079
Rep 3,031
Drives: E90 330xi
07-20-2020, 08:04 AM | #16 |
858
Rep 1,363
Drives: 09 E90 335i M-Sport 6MT RWD
My brother has a E90 328 (no exhaust valve) but with his job(having clients in his car) a real exhaust is out of the question. We are on the OEM+ route; so wee found a 330 resonator back(a bit louder and slightly bigger dia res to muffler) plus it has the valve. We will be doing a secondary delete as well which this exhaust set up is technically oe in some euro countries.
I'm sure we will just be doing the golf tee mod but the idea of the valve for a quieter idle and cruising speed is intriguing. I grabbed an exhaust solienoid+hose and I have a few 330i parts cars I can pull from. I can run the vacuum line to the engine bay no problem; Just have to trace it and find out where it goes to. Also the wiring I can pull from the car but does any have any idea where they go to(which module?) or if the 328 ecus can actuate the valve? |
07-20-2020, 08:41 AM | #17 | |
eBay Special
3079
Rep 3,031
Drives: E90 330xi
07-20-2020, 08:49 AM | #18 | |
858
Rep 1,363
The wiring also seems to follow it, traced that to the back seat area but I expect it to follow the same route. I wonder if both go to a vacuum pump that is in the engine bay somewhere, maybe close by the booster? |
07-20-2020, 09:06 AM | #19 | ||
eBay Special
3079
Rep 3,031
Drives: E90 330xi
It could just be a control unit located in the trunk if I remember correctly.. It's been awhile since I've messed with it. https://www.realoem.com/bmw/enUS/sho...diagId=18_0612
07-20-2020, 09:08 AM | #20 | |
858
Rep 1,363
The wiring also (which isn't there on the 325/328 cars) runs that way but I haven't fully traced that yet. |
colorado.e9x3079.00 |
07-20-2020, 09:15 AM | #21 | ||
eBay Special
3079
Rep 3,031
Drives: E90 330xi
