Shuddering after pull, need some input
07-05-2020, 01:46 PM | #1 |
1069
Rep 945
Drives: e92 335i, f22 m235i, e30 325is
Hi all, car did something odd last night after a slight pull. Haven't had a chance to datalog but will later today for better info. In the meantime, wondering if I could get anyone's 2 cents in
I did a small pull yesterday afternoon and although my passenger was wow'd, I felt like the car was a underpower from how it normally was. I chalked it up to being the 100f weather and disregarded. However, later that night when it was much cooler, I did another pull. Afterwards, I could feel my car shuddering/chugginng a bit, especially under decel/engine braking. Steering wheel felt like power steering was cutting in and out as well. I was about to pull over when the symptoms stopped and car was back to normal again. (Didn't do any further pulls because I was about 50 miles from home and didn't wanna get stranded) I also remembered just a few weeks ago, I had driven from NorCal to socal and during a gas stop, the car started idling funny while I was sitting at a red light. But after light turned and I went, idle issues disappeared from all further stops I'm really hoping these aren't the precursor symptoms indicating the hpfp finally going out. But not sure what else it could be? Misfire related to ignition? My spark plugs are brand new, only about 5k on them. BMW told me my injectors were replaced under the recall several years ago but couldn't tell me what index was currently installed. I believe my coils are original though Codes: 29E0, 29E1, mixture control Also 1 shadow code keeps coming back over the past couple months, not sure if related as this one pops up even without noticeable performance effected: 2FDB, crankshaft positioning sensor, signal not plausible No recent mods aside from catback exhaust swap and redoing vac hoses. Car is currently running MHD1+ I dumped a bottle of techron into my tank about 5 gas fills ago. Not sure if that's a contributing factor Planning on doing a log later tonight to get some solid data to look at. Last edited by ky0u; 07-05-2020 at 02:24 PM.. |
07-05-2020, 10:50 PM | #2 |
Davy Jones, Giant Squid
271
Rep 913
Mixture codes can be related to Injectors or Pre-cat o2 sensors
2010 e90 335i LCI - xHP - Mishimoto - BMS - CPe - Turbosmart - MHD - Eibach - Koni - VMR - LUX
