07-03-2020, 05:43 AM | #1 |
67
Rep 223
Is backbox delete MOT fail?
As per title, under the new MOT rules is a backbox delete an MOT fail? I've been told it's been changed to you must have the required number of silencers for your car.
For those who have had it done have you now run into any issues come MOT time? I've only got the single exhaust on my 320D and wanting to convert it to a twin tip. Custom exhaust shop recommends a backbox delete but if it's illegal then I will go for the BMW retrofit instead where you just cut the single tailpipe off and clamp on the twin tips.
BMW F30 320D EfficientDynamics
Stage 1 remap, EGR delete, 398 alloys, tinted windows, M Sport front bumper, M Performance grilles, M Performance spoiler, gloss black mirrors, tail light tints, debadged. |
07-03-2020, 05:45 AM | #2 | |
541
Rep 1,894
07-03-2020, 06:11 AM | #3 |
6426
Rep 8,501
No, it's not parts of the emissions controls so it won't have any effect on the MOT as long as the car is within noise limits.
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
07-03-2020, 07:43 AM | #4 |
67
Rep 223
Yeah I know the retrofit won't be a problem as the back box will remain however I would prefer to go custom so I can choose my own tips to be welded on as I want black instead of stainless steel. The only issue is though if I go custom then the shop want to delete the backbox altogether.
I know it shouldn't be a problem for noise or emissions but apparently you must now have the required number of silencers for your car so without the backbox I guess it would technically fail?
07-03-2020, 07:45 AM | #5 |
185
Rep 475
07-03-2020, 09:50 AM | #7 |
142
Rep 267
I had my rear silencer deleted in May, I asked my MOT guy before I had it done and he said NO problem as the cat and resonator were still in place and it didn't affect emissions and didn't do much for noise anyway so back box delete is fine
The Alpina above has a lot of pipework on show, if I was sat in a car behind it, that's all I would see, which is why I had the pipework on mine redirected up into the cavity where the rear silencer was so anyone sat behind me only sees the tips, plus the pipework is sprayed in heat resistant black paint
I don't eat raw meat unless it's wearing red stillettos
Fez_766.50 |
07-03-2020, 10:44 AM | #10 |
142
Rep 267
The MOT deals with emissions and whether there are holes or corrosion on the exhaust and excessive smoke, not noise, otherwise all the McClaren's, Lambo's and Ferrari's etc would never pass a MOT due to excessive noise.
I've never known the silencers be counted on any of my cars and I watch the MOT being done, to the extent that I'm under the car with the guy when he's checking it on the lift But I'm not an expert
07-03-2020, 12:34 PM | #12 |
67
Rep 223
Thanks for all the responses, seems like its up to the testers discretion then so don't know whether it's worth the risk.
Safest bet will be the BMW retrofit. Has anyone with standard twin tips (I think 70mm / 2.75") found any black or carbon sleeves to fit over the stainless steel tips, or is this not possible? Alternative option will be to go custom but ask them to keep the backbox or make a new one?
07-03-2020, 03:41 PM | #13 |
142
Rep 267
You can buy an exhaust system , dual tips with a back box like the Cobra system, but be prepared to pay £500-600 plus fitting, mine is legal and meets all MOT criteria for less than a third ( £180 ) of that, mine isn't noisy, just a slightly deeper tone.
It's horses for courses, do whatever you feel is right, I did
