06-27-2020, 06:18 PM | #1 |
56
Rep 72
Continuation of music playing after exiting M5C
Has anyone noticed that on some occasions the music will continue playing after the vehicle has been shut off AND continue to play after you've opened the door to exit? So today after noticing this "feature" happening over and over, I've realized that it only happens if the car detects that the passenger seatbelt is still connected (buckled in). I usually travel with my dog in the passenger seat and I purchased a harness that goes into the seatbelt buckle to keep him secure. On a few occasions, I've opened my door to blaring music for the general public to hear, which I find annoying.
Now for the question... How do I turn that off?? Is there a setting in Bimmercode for this? I've been looking all around and can't find any information on to adjust this. |
06-27-2020, 10:09 PM | #2 |
857
Rep 703
I believe this can be set in the "Vehicle settings" under "My vehicle". Under "doors/key" there's a setting "turn off after door opening"
See below:
2023 M3: Isle of Man Green
2021 X7 40i: Phytonic Blue |
06-27-2020, 10:16 PM | #3 |
Rep 23
Same problem, I made the changes in iDrive. There have been previous threads about this but no solution. My lease is up in six months so I've given up on looking for a solution
06-27-2020, 11:37 PM | #6 |
369
Rep 1,887
Drives: '20 M5C, '09 M3 DCT Coupe
Yes, it's in iDrive, but I noticed it would still stay on sometimes. I found it was due to me opening the door at the same time as shutting off the engine. So I try to stay in the habit of waiting half a beat after I shut of the engine before I open the door.
M5C 20% tint, Xpel full front, partial sides and rear. Spacers, 15mm front, 12mm rear. Turner Motorsport Oil Cooler Guard.
M3: Active Autowerke filter, Dinan underdrive pulley, Dinan full exhaust and software, 3.45 Differential, Springs, Brakes, Dinan/HRE wheels, 275/30-19 w/10mm spacer, 295/30-19 w/3mm spacer, painted front reflectors, 30% tint, Escort 8500i & Lidar Jammer, LUX H8 V5 halos, Euro rear foglights, 3M ClearBra. |
06-28-2020, 12:35 PM | #7 |
91
Rep 183
Ha! I thought it was just me and not knowing how to operate the doors or something...
It is annoying, and probably wouldn't bother me as much if I knew how long it takes for the car to finally turn off. I feel like it could drain the battery... |
06-29-2020, 09:15 AM | #9 |
123
Rep 105
Happens on mine too. I went to pump gas one day, turned off the car, opened the door too soon. Car was playing the tail end of "every breath you take" on medium volume. I start pumping gas wondering what will play next on my playlist. "Straight Out Of Compton" Embarrasing. Lol!
06-30-2020, 03:13 PM | #10 |
31
Rep 127
From my experience this has to do with a combination of the source, connection type as well as gear ignition and seat belt. Granted, Im not sure the exact combination that causes this I can tell you that its likely to happen to you a few times. Its just one of those random glitches that happens. Just like randomly your seat wont go back to normal even after you put your seat belt on.
Past Builds
2015 Alpine White M6 2017 Melbourne Red X5M 2020 Black Sapphire M5 Comp |
06-30-2020, 03:55 PM | #11 |
26
Rep 32
I have found the exact same thing.
06-30-2020, 04:47 PM | #12 | |
56
Rep 72
06-30-2020, 05:12 PM | #13 |
1977
Rep 4,225
06-30-2020, 05:33 PM | #14 |
29
Rep 63
On my M550 at least, it has to do with whether you turn the car off with the brake pedal engaged or not. Try that. Depress the brake pedal, and turn off. And then test turning it off without the brake pedal depressed.
T |
07-02-2020, 10:48 AM | #15 | ||||
123
Rep 105
