06-25-2020, 12:35 PM | #1 |
230
Rep 525
Brake bleeding - do i have to cycle it through ABS?
last year before a track day, i swapped the brake fluid over to some Motul 660, used my brake bleeding kit, went and did the track day, all ended well.
afterwards the car went in and as part of another ongoing issue i'd had, they gave me a free brake fluid service (without telling me first....was supposed to be a nice gesture). anyways, i told them i hadn't wanted it and i had expensive stuff in there, after some apologies they mentioned that in order to bleed the brakes properly, it has to be run through the computer so it flushes through the ABS pump. Now....i wasn't aware of this, and the car performed fine on track, no issues with brakes in terms of pressure. So - do i actually need to do it via the computer? If the answer is a categorical 'yes'...then is there a guide anywhere? |
06-25-2020, 12:39 PM | #2 |
8245
Rep 16,089
The answer is no. You may, but you don't have to. There are ways to fully flush the system with a manual pump. You can find how-to's on youtube. You may even do it the old fashioned way, with one bloke pumping the brakes while another mans the bleeder screws.
obert1781.00 |
06-25-2020, 01:04 PM | #5 | |
4528
Rep 5,394
Drives: 2015 BMW 335i x-Drive Auto
obert1781.00 |
06-25-2020, 05:25 PM | #7 |
8245
Rep 16,089
This ensures a full bubble free flush, and has the advantage of being a one man job.
06-25-2020, 05:34 PM | #8 |
559
Rep 1,127
I have used a motive power bleeder 6 or 7 times now on my cars. I think if you completely drained and refilled the system then you might very well need to have the computer trigger the abs pump. If you are just flushing the fluid and keeping the system fresh I haven't needed to do that yet.
gippy230.00 |
06-25-2020, 06:26 PM | #9 | |
230
Rep 525
if you don't know what i'm asking, please dont spam stuff. Last edited by gippy; 06-25-2020 at 06:34 PM.. |
06-25-2020, 06:31 PM | #10 | |
230
Rep 525
though i have to ask....what difference are you implying between a complete drain/refill vs flushing fluid through? EDIT: i've figured out what you mean - complete drain and refill the system = ...just that. flusing fluid and keeping system fresh = just that (lol) - flushing through to remove any air/moisture build up and topping with new fluid. am i right? Last edited by gippy; 06-25-2020 at 08:40 PM.. |
06-25-2020, 09:40 PM | #11 |
8245
Rep 16,089
I read your post and replied to it. I then read a post with a different question from a different person and replied to it. I never spam. Wanker.
MacklinUSOB518.00 |
06-26-2020, 06:46 PM | #12 | |
559
Rep 1,127
06-27-2020, 06:17 AM | #13 | |
6422
Rep 8,501
Biting back isn't going to help you solve your problem.
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
MacklinUSOB518.00 |
06-27-2020, 08:40 AM | #14 | |
230
Rep 525
i don't want random spam on the thread, then people start jumping in and giving their opinions about how to bleed brakes......and it becomes a mess. I was asking a very specific question about the ABS pump and issues around changing brake fluid and not bleeding any old fluid through that pump, given the other forum thread that i'd already been through talking about it. His first response to me made no sense, given the OP, then he posts a video which he then claimed was in response to someone else. I'll bite at people who post stupid posts. And i'll apprecaite those who read the post and take the effort to answer what is being asked. |
06-27-2020, 08:42 AM | #15 | |
230
Rep 525
yeh like i said i didn't have any issues with the brake response or firmness of the pedal when i flushed it last time before going on track, without running the ISTA abs pump procedure. I guess i'll skip that step and monitor it. |
06-27-2020, 05:35 PM | #16 |
6422
Rep 8,501
If you can't work out, from the several replies on two sections of the forum, that the answer to the question "do I need to cycle the ABS pump when bleeding the brakes" is "no" then you're on your own.
Stop acting like an ungrateful child. I'm out. Solve your own problems.
obert1781.00 MacklinUSOB518.00 |
06-28-2020, 06:48 AM | #18 | |
230
Rep 525
i've had adequate responses from both threads to decide to not bother going down the ISTA pump route for the time being. stop strawmanning stuff up to make points. and i'm not acting like an ungrateful child.......like i said i appreciated and responded to the posts which made sense. I posted on the UK forum the same question because of the lack of/poor responses i got in the brake forum, and because people who go to the UK forum generally might not visit the general/maintenance sections. The americans decided to have a conversation all on their own about bleeding brakes which had absolutely nothing to do with the specific question i was asking, about bleeding fluid out the ABS pump and how that would effect the system as a whole - which is a pertinent question as its not been asked anywhere, after i googled for a while, which is exactly why i posted it. If i hadn't wrote that message telling him to stop it would have probably turned into an endless string of 'how to bleed your brakes' to add to the 30 that are already on here. You for some reason decide to find my post, in the brake forum, read through it, then complain about a completely separate issue where i wrote a short message to some other guy telling him to not bother posting messages about how to bleed brakes. i think you're the one with the problem Last edited by gippy; 06-28-2020 at 06:55 AM.. |
06-28-2020, 12:03 PM | #19 | ||
1307
Rep 1,827
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
alohasurftoad3081.50 MacklinUSOB518.00 |
