06-22-2020, 12:48 PM | #1 |
54
Rep 127
Digital keycard
I have activated the keycard and gotten it to work.. A few times. The first day it opened and closed and started the car. The past week it only opened and started the car, it would not close it. The past few days it doesn't open or close the car at all, only lets me start it. I was actually stuck outside the locked car here the other day when i realized i could just open the car using the iPhone connected drive app (which i did), and then i could drive off using the keycard in the charging spot.
What is happening with this keycard? Am i doing something wrong? I though i had found the sweet spot on the handle, but this no longer works. I spend five minutes trying to open/close the car to no avail.. It has always started the car, but the open/close is buggy.. Others with the same problem? Solutions? Thanks |
06-22-2020, 01:01 PM | #2 | |
456bhp for breakfast
425
Rep 913
https://g05.bimmerpost.com/forums/sh....php?t=1628624 |
06-22-2020, 01:48 PM | #3 |
54
Rep 127
Yes I have, thanks for the tip. As I wrote, I have gotten it to work many times, and i fine tuned where to put the card to have it opening the car on first attempt. But something has happened as it no longer works. I keep it at the exact same spot - I've also tried all over the door handle - but it doesn't work....
06-22-2020, 02:26 PM | #4 | |
74
Rep 108
06-22-2020, 03:13 PM | #5 |
54
Rep 127
Reactivated, optimized keycard orientation when opening/closing. Now it worked several times flawlesssly, hopefully it will continue working.
thanks for all feedback and tips!! |
phillydilles74.00 |
06-22-2020, 03:18 PM | #6 |
54
Rep 127
An error I made was to orient the card vertically in stead of horizontally. Also I tended to hold the card facing up/down (perpendicular to car) rather than back/forth (parallel to the car).
FYI |
phillydilles74.00 |
03-09-2021, 03:51 PM | #8 |
108
Rep 242
03-09-2021, 04:22 PM | #9 |
156
Rep 289
I did not get it and dealer says they don’t have any that came with my car.
Can I buy it as a BMW part or actually can I buy some oem key card on amazon? |
