06-20-2020, 07:02 PM | #1 |
108
Rep 473
F30 340i xDrive Alignment specs
Hi guys, I just got allignment today after a week of installing my h&r springs. Here are the specs. It looks like my front left camber is slightly off. From my understanding you can't adjust it on these cars. Is something potentially wrong with my strut mount or lower control arms?
2016 Alpine White on Coral Red 6MT 340i xDrive
06-20-2020, 11:18 PM | #2 |
4017
Rep 3,540
Drives: 328d Wagon, M2 Comp, i4 eD35
There's a small amount of play in the bolt that mounts the LCA/Wishbone to the subframe. The only way to really adjust camber is to try and pull/push the bolt to the edge of the play it has and clamp it there. I don't think you'll get more than 0.1 or 0.2deg that way though.
I recommend dialing less toe (0.05deg in each side, front and rear), and less rear camber (-1deg both sides). It'll make the car feel a lot more nimble.
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
06-20-2020, 11:29 PM | #3 | |
108
Rep 473
Hmm you're right, I'm going to see if I can get less toe and camber, as the steering feels alot more vague than before I went into the alignment. I'm assuming a bit less toe and rear camber will make the steering a bit more tighter? Shouldn't the toe be slightly higher in the rear than front?
06-20-2020, 11:33 PM | #4 | |
242
Rep 765
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
06-21-2020, 12:28 AM | #5 | ||
4017
Rep 3,540
Now regarding popping axles, that depends on how low you are. I ran -1.5deg up front no problems with a mild lowering with xDrive (about .5"). Folks that have popped axles were lowering much more, like 1" or greater IIRC. Toe doesn't need to be higher in the rear than front. It just has to be enough to keep the rear end straight on acceleration. IME 0.05deg in each side is enough to keep the car tracking straight. If you're really worried about it though you can go 0.08 or 0.1deg in each side for the rear. Toe is what causes the most tire wear though (more than camber). Quote:
06-21-2020, 10:39 AM | #6 | |
108
Rep 473
Regarding axle popping, I'm 1.6" lower front, 1.5" in the back. H&R sport springs for xDrive Last edited by Nexus313; 06-21-2020 at 11:18 AM.. |
06-21-2020, 12:28 PM | #7 | |
4017
Rep 3,540
I wouldn't go greater than -1.4deg negative camber given your drop amount. The risk is exacerbated if your LCAs are pointing up at static height (knuckle end of the LCA is higher than the subframe end).
06-21-2020, 01:47 PM | #8 | |
108
Rep 473
My alignment guy is saying that if I go -1 camber in the back my tires will be toast by winter.. hmmm I'm having trouble believing that. |
06-21-2020, 03:48 PM | #9 |
4017
Rep 3,540
That makes no sense at all. It'll actually have more even tread wear there during normal driving. The reason you go to more negative camber is for more grip in hard cornering.
06-21-2020, 04:15 PM | #10 |
108
Rep 473
06-23-2020, 10:26 AM | #12 |
4017
Rep 3,540
It'll reduce wear. The more toe in or out you have, the greater the wear. So by making the toe closer to straight ahead you'll reduce the wear. What you should shoot for is the least amount of toe in needed so the car tracks straight, which is about 0.05deg in on each side IME.
06-23-2020, 10:45 AM | #13 | |
108
Rep 473
Is there any downsides at all to this configuration? And is it how you are running it aswell? |
06-23-2020, 11:27 AM | #14 | |
4017
Rep 3,540
Since I track my car, and have hardware that gives me more adjustability, my numbers are different for camber (I run -2.5deg front and -1.7deg rear), but I tune my toe the same (0.05deg in each side for the front and 0.05 to 0.1deg in on the rears). You can see it's in the same spirit/ideology as what I told you. Before I started tracking the car I aligned it the same as what I recommended to you. The only downside is if you're driving to the tires' limits like autocross of HPDEs the overall rear grip will be less. This shouldn't be an issue daily driving or "fun canyon" driving.
06-23-2020, 11:32 AM | #15 | |
108
Rep 473
Will let you know how it goes with your recommendation. Maybe ill make a post for others who put H&R on since I couldn't find this info PRE-allignment haha.
06-25-2020, 11:14 AM | #16 |
108
Rep 473
Here's my new alignment spec. Feels ALOT better .. decided to go with the 0.07-0.08 range for toe in the rear just to be safe. As for the rear camber, it maxed out at -1.16/-1.18 and wouldn't go lower to -1.
Turns out the first guy who did my alignment, the numbers on his sheet were totally wrong in comparison to when the car went onto a different alignment rack. Toe was all out of wack.
