06-14-2020, 09:49 PM | #1 |
58
Rep 158
Ordering JB4 anything I should know
I'm about to order a jb4 for my 2020 m5 com. Im probably going to order from burger tuning. Just want to make sure there isn't anything I need to know before ordering.
Thanks Joe |
06-15-2020, 07:05 PM | #2 |
245
Rep 95
MikeStammer154.00 |
06-15-2020, 09:04 PM | #4 |
366
Rep 804
Just make sure it's installed correctly and start with Map 1, anything higher and you'll need better fuel than 91 or 93oct. Check to make sure your phone connects so you can switch maps and log if you want to and then let it adapt for a few wide open throttle pulls and you should be good to go
Blue M558.00 limeypride4425.00 |
06-16-2020, 10:12 AM | #6 | |
Joint Chiefs of Staff
24199
Rep 190,807
Instead of ordering direct, please support a forum vendor. Its the same price
06-16-2020, 07:30 PM | #7 |
58
Rep 158
limeypride4425.00 |
06-16-2020, 09:01 PM | #8 | |
58
Rep 158
06-16-2020, 09:14 PM | #9 |
366
Rep 804
If you have any issues for any reason you can send logs to the support page on the n54 forum. Also if you want to create a custom map 6 you'll need to make adjustments and then send the logs to see that everything is running within safe parameters. Once you install the JB4 and the EWG cables for wastegate control you can run map 2 with a few gallons of e85 mixed in or 100oct so you're above 91-93oct, you can run map 1 with 91-93oct and you dont have to connect the EWG just OBDII and TMAPS but it's recommended to install the EWG's.
06-17-2020, 07:38 AM | #10 |
IG @bmwF9xG80
3813
Rep 7,593
If you dont want to have engine wires sitting in engine bay, contact @TristateBM3 they're local to you for a Flash
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
06-17-2020, 03:46 PM | #11 |
366
Rep 804
06-17-2020, 08:18 PM | #12 | |
58
Rep 158
06-17-2020, 10:21 PM | #13 | |
58
Rep 158
06-18-2020, 02:34 PM | #14 |
366
Rep 804
No more than 20% from what i have understood about the limitations of the F90 fuel system. Your tank is 20 gallons so 16 of 91-93 and 4 gallons of E85 would be the max, i usually put in 3 gallons and i have been running map 2 flawlessly for months now with that mix.
06-18-2020, 03:17 PM | #15 | ||
461
Rep 524
The trick is knowing how much ethanol is actually in the fuel source you're using. I have some pumps nearby that specify they are e85, but have a disclaimer stating they could actually be 60-83% percent ethanol. So, I use the calculator at the below link. For every 10 gallons of 93 octane, I use 6 gallons of pump 'e85'. If the 'e85' only has a true ethanol content of 65%, that puts my mix at e31. If the fuel actually has an ethanol content of 80%, that puts me at e36. I've been running this way for a long while. Many logs, many reviews with tuners, car runs healthy. I did run a couple of tests using e98 from a pail (exactly 98% ethanol content). No real difference in performance or logs. http://www.wallaceracing.com/ethanol-mix-calc.php |
06-18-2020, 05:50 PM | #16 | |
4425
Rep 4,109
// that's "used to... ", by the way. With such attention to detail, I'll be sure to weigh your input with appropriate value. Last edited by limeypride; 06-18-2020 at 06:38 PM.. |
06-18-2020, 05:50 PM | #17 | |
366
Rep 804
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
limeypride4425.00 FloridaM5461.00 |
06-18-2020, 05:51 PM | #18 | |
4425
Rep 4,109
"It wasn't my fault—I know cars; must've been the shitty product." Sheesh. Last edited by limeypride; 06-18-2020 at 07:49 PM.. |
BMWDriverX365.50 |
06-18-2020, 05:53 PM | #19 |
4425
Rep 4,109
06-18-2020, 06:01 PM | #20 | |
4425
Rep 4,109
BMWDriverX365.50 Blue M558.00 |
06-18-2020, 06:02 PM | #21 | ||
461
Rep 524
Blue M558.00 |
06-18-2020, 07:01 PM | #22 | |
366
Rep 804
