06-14-2020, 12:12 AM | #1 |
87
Rep 109
Drives: 2019 x5 50i, 2020 m5
BM3 stage 1 e30
Just wanted to share a problem i've been having after i flashed stage 1 e30 bm3 ots map on my 2020 m5. Car works great can definitely feel the power in gears 1-5. When you shift into 6th gear and onwards the gas pedal becomes literally unresponsive. Rpms don't shoot up and car just starts rolling as if it's in neutral but you can't even rev it while in 6th. Tried flashing back to stock and re flashing but problem still exists. My tank is filled with the e30 mix so will try to burn it then flash to stock and drive on stock and see if problem exists.
06-17-2020, 07:35 AM | #2 |
IG @bmwF9xG80
3813
Rep 7,593
Did you email support@protuningfreaks.com ?
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
06-17-2020, 10:35 AM | #3 |
Joint Chiefs of Staff
24199
Rep 190,807
Since the problem occurs on stock flash, it does not sound like a problem with bm3.
Its either the car of the fuel mix. You are on the right track, try stock map with 91/93 octane and let us know if it goes away
06-17-2020, 11:32 AM | #4 |
366
Rep 436
Should you run upgraded injectors when running E30 or any other fuel?
I ran a FlexFuel Kit on my C63 so I can use E85 and I had to upgrade my injectors to 500cc injectors. This kit includes the necessary adapters for the injectors. My question is, is it safe to run throw in E30 or E85 in the car without any other modifications? |
06-21-2020, 09:57 PM | #5 |
87
Rep 109
Emailed bm3 they gave me a new map and the problem was solved.
06-21-2020, 09:58 PM | #6 | |
87
Rep 109
06-21-2020, 09:59 PM | #7 |
87
Rep 109
problem did not occur on stock map. only on stage 1
06-21-2020, 11:12 PM | #8 |
24k GOLD
148
Rep 1,453
I ran stage 1 e30 no problem. Very happy with stage 2 93. The agg map is straight up dropping bombs with my resonator delete. Anyone know how much more psi is stage 2 e30 running?
06-22-2020, 01:19 AM | #9 |
1105
Rep 1,607
Drives: 2020 M8 Comp First Edition
Glad u got the issue fixed. I'm running e38 right now with Eurocharged Stage 1 tune with some exhaust mods. Will be changing secondary cat soon. Would love to know if e50 is possible in our cars or what's the safest blend to run. Thanks
GT
2020 BMW M8 Comp First Edition 2019 Panamera Turbo 2021 BMW X6M Comp 2019 BMW M5 2018 Maserati Ghibli SQ4 GranSport |
06-22-2020, 08:56 AM | #10 |
24199
Rep 190,807
06-27-2020, 02:03 AM | #11 |
87
Rep 109
06-27-2020, 03:46 PM | #12 |
In the Details
1810
Rep 867
Drives: Yes
Garage List 2020 AMG GTR [0.00]
2022 R8 Quattro Spyder [0.00] 2023 X5M50 [0.00] 2023 718 Spyder [0.00] 2024 Silverado [0.00] 2024 Civic Type R [0.00] |
my car also will completely shut off (like engine not running, have to restart) under heavy throttle with the BMW Stage 2 E30 tune. Went back to Stage 1 93 and all is good. They need to roll out whatever changes they made for your car to everyone, no updates for the files are showing on my devices.
JBA87106.50 |
06-28-2020, 11:04 AM | #13 | ||
87
Rep 109
06-28-2020, 11:47 PM | #14 |
24k GOLD
148
Rep 1,453
Can anyone running bootmod3 stage 2 confirm that Their sport meter in the car goes pass 600hp? I cant get my meter to go pass 600hp no matter what I do. But on a side note I walked a hellcat on a few good runs.
07-05-2020, 10:13 PM | #15 |
87
Rep 109
07-07-2020, 11:10 PM | #16 | |
24k GOLD
148
Rep 1,453
07-08-2020, 10:21 AM | #17 | ||
87
Rep 109
07-08-2020, 11:08 AM | #18 | |||
24k GOLD
148
Rep 1,453
