06-13-2020, 11:15 AM | #2 |
1702
Rep 2,610
Interesting. After the update, does your FA now have 5AP back in?
G05 X5 x40i (04/2019 mfg, Canada) on S18A-19-11-540
06-13-2020, 11:17 AM | #3 |
1053
Rep 1,952
06-13-2020, 11:19 AM | #4 |
1702
Rep 2,610
Ok, then at least it makes sense. OTA update includes FA restore per your VIN. That actually seems prudent for a hands-off update, even if annoying for coders. Good to know.
06-13-2020, 10:09 PM | #5 |
49
Rep 64
Heck I would be just fine with having to re-code everything if it means OTA actually takes place and works.
russelldav424.50 |
06-15-2020, 08:55 AM | #6 | |
1053
Rep 1,952
When I VO coded my anti-dazzle, I followed Token Masters steps, which doesn't involve writing the the new FA to the car. You just remove 5AP and code the necessary ECUs. If I'm not mistaken, when you VO code this way, the next time you read the FA, it will show the 5AP on the list. However, if the OTA update "CODES" all the ecus, then it will revert the ECU back to the FA with the 5AP - so that may be an advantage to writing the FA back to the car after you edit out the 5AP. I'm too novice to know which is the best way to go moving forward. |
06-15-2020, 10:29 AM | #7 | ||
1702
Rep 2,610
06-15-2020, 10:59 AM | #8 | |
1200
Rep 1,587
When you get an i-step update, whether via ISTA, esys or OTA, it programs each ECU and then codes the ECU. It uses your car FA when doing the ECU code, and its the same as VO Coding. Obviously any FDL coding will be wiped, and the coding will reflect what is set in the car FA - model type, build version, options (inc 5AP if still in the cars FA), language, etc |
06-15-2020, 11:03 AM | #9 | ||
1702
Rep 2,610
06-15-2020, 11:54 AM | #10 |
1200
Rep 1,587
I've never heard of the FA being rewritten. The only times it might get changed is for a dealer retrofit of an option such as remote start, or when dodgy owners start coding.
06-15-2020, 01:56 PM | #11 |
35
Rep 105
I had the same issue with OTA software update and now my ASS does not maintain last setting which I coded with Bimmercode. I just tried recoding it back in and now I get an error message and it will not code. Any one else run into this problem? The ASS was the biggest benefit.
06-15-2020, 01:58 PM | #12 | |
1053
Rep 1,952
06-15-2020, 02:00 PM | #13 |
35
Rep 105
06-15-2020, 02:10 PM | #15 |
1053
Rep 1,952
