Need help with PDC Malfunction
06-08-2020, 01:07 PM | #1 |
Rep 24
Drives: 2009 328i
Hi,
I have completed installing a rear camera on my daughter’s 2009 328I To help her keep from hitting things when backing up. Her BMW Build date was 5/2009 and did not have either PDC or rear camera options but did have CIC iDrive. I updated her CIC version From C0A to C16. I removed a PDC system from a junkyard donor and installed it with a camera and emulator and Have it working except for a PDC Malfunction. The malfunction is probably from my not installing the PDC sensors because I just needed the rear camera. I have the sensors and might install them in future when the car is eventually repainted, but not now. So to code the new OEM PDC Module and Rear Camera I added the following CIC option coding: MACRO_CAM_LEGALDISCLAIMER kein_ld MACRO_PDC aktiv MACRO_PDC_TOPVIEW aktiv MACRO_REARVIEW aktiv RVC_CIC wert_23 LEGAL_DISCLAIMER_TIME kein_ld MACRO_L6_PARKMENU aktiv TVC_WIDTH_0C wert_02 PDC_DIRECTION vertical PDC_SENSOR_HINTEN kein_sensor So I am getting the PDC Malfunction: Park Distance Control No warning available from Park Distance Control PDC. Have the system checked by your BMW center as soon as possible. I tried plugging the sensor harness in hoping to clear the error but the warning still came on and the PDC alarm sounded with no color field shown. I thought the PDC_SENSOR_HINTEN “no sensor” code would have disabled the rear PDC but it did not work. The warning is very annoying every time. HELP, DOES ANYONE KNOW HOW TO CODE OUT THIS WARNING? |
06-08-2020, 02:11 PM | #2 |
185
Rep 780
Why did you add PDC? That's not needed for reverse camera retrofit. Disconnect PDC module, remove $507 or $508 depending on if you installed front and rear or just rear and code the car with just the reverse camera.
06-12-2020, 02:29 AM | #3 | |
Rep 24
Drives: 2009 328i
I only found out the PDC malfunction after getting it altogether. My daughter just has to click the wheel to use and it is worth it for her to have the rear camera. But I believe the error should not be necessary to live with. Using NCSDummy I have been going through the various ecus trying to find warning or error display command but cannot find the module or command. Thinking will have to use ISTA-P to remove the warning display. But not sure. And I believe it is possible to code it off since praticaly everything rise is. Thanks for any direction. David |
06-12-2020, 04:03 AM | #4 | ||
185
Rep 780
