F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > New here.. lowering and need advice/pics
ARMA SPEED
      06-07-2020, 03:09 PM   #1
erock9969@yahoo.com
8
Drives: 2015 BMW 320i
Hey yall! Ready to start modifying my 2015 320i xdrive. starting with suspension. Ive used eibach pro kit in the past but feel .8" drop might not be enough, and the sportline option might be too low. Anyone have pics of either installed? And what shocks/struts would be best? This is a DD.
Any info/advice is appreciated!
Brand new to the BMW scene... be gentle!
2015 320i xdrive bone stock... for now.
      06-07-2020, 04:00 PM   #2
cfm56d7b
Drives: 2017 440i Gran Coupe & 2015 X5
What's your budget for this suspension project?
      06-07-2020, 04:23 PM   #3
erock9969@yahoo.com
8
Haven't really put an amount on it but not looking to go crazy. Under 1k for parts.
      06-07-2020, 05:22 PM   #4
alohasurftoad
3082
Drives: 440i gran coupe w/mppsk
there are two eibach pro-kits, 5-22(0.8"/0.6") and 6-22(lower than 5-22). xpro has pics of both here... https://f30.bimmerpost.com/forums/sh...1&postcount=10
i'd get the eibach 6-22 with koni sport yellow dampers.
johnung4528.00
      06-07-2020, 07:02 PM   #5
erock9969@yahoo.com
8
6-22 must be the sportlines? I'm thinking I'll probably go with the prokit. I'm also not throwing a coil over set out the door I just don't know much about them yet.
      06-07-2020, 07:30 PM   #6
johnung
Drives: 2015 BMW 335i x-Drive Auto
Here are the part numbers off the Eibach website. If you go with the bigger drop definitely consider Koni Yellows.
If you go with smaller drop you would be in range to use Koni Special Active Shocks. Developed with McLaren it works at two frequencies to be a sport shock and comfort shock. I've had this combo for two years and they are awesome!
      06-08-2020, 05:04 PM   #7
erock9969@yahoo.com
8
Awesome ty! So another question... anyone here have KW coilovers installed and if so what are your thoughts? Worth the $1,400?
      06-09-2020, 12:24 AM   #8
DreamerJoe
Drives: 2017 340i M.G. w red interior
if you're looking to save money you can also look into ST coilovers, very close to the KW V1 (ST X) and V2 (ST XA), except the KW's are stainless steel so hold up much better to corrosion and have a lifetime warranty. the ST's are galvanized, so snow and salt roads won't be kind, and a 5 year warranty.. I live in SoCal so went with the ST XA's and they feel great, slightly firmer than stock and still very comfortable.. only negative thing I noticed was once I hit a bumpy part of the road at ~50/60mph and it felt a little rough, not sure if a better coilover would have handled it much better, but maybe.. or may need to adjust mine because it's set in the middle now.
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
      06-09-2020, 02:10 AM   #9
s55jesus
M Enthusiast
s55jesus's Avatar
438
Drives: 2018 F80 M3 ZCP
  [0.00]
+1 for ST XA coilovers. Like he stated already, it's essentially the same thing as KW V2's for a lower cost. Difference is the material.
2018 F80 M3 ZCP - CCB - MPE - BBS RI-D - Pure Turbos Stage 2+ - 3D Design Bumper - KW Clubsport 3 Way - Cary Jordan E85 Tuned
2021 F97 X3MC
2017 F30 340i (SOLD)
2015 F82 M4 (SOLD)
      06-09-2020, 11:44 AM   #10
erock9969@yahoo.com
8
Thanks for the info! Im learning alot about coilovers. Once Installed do you have option to bring back to stock height and lower it down when wanted? Ive also heard you need to get an alignment every time you adjust height... that true?
      06-09-2020, 08:53 PM   #11
DreamerJoe
not sure if the coilovers will be at stock height, but they let you adjust how much of a drop you want to a degree, some coilovers go lower than others but my goal wasn't to go low just reduce some wheel gap and keep it comfortable. as for needing alignment, it is recommended when messing with the height of the car, the more you lower it, the more it will be off.
      06-10-2020, 02:48 PM   #12
erock9969@yahoo.com
8
Ok cook. Thanks for the response. Its tricky trying to figure all this out and its a bit pricey! I'm leaning toward the H&R street kit. Anyone have any experience or thoughts on that kit?
      06-10-2020, 03:28 PM   #13
johnung
Different coilovers kits come in different adjustment ranges so don't just assume that stock height is within that range. Verify
      06-11-2020, 09:12 PM   #14
erock9969@yahoo.com
8
Yes thats true. So what I want to achieve is the option to go to stock height "roughly " and be able to lower up to 2".
Im looking at the kw v1, Bilstein b14 and HR.
I've never had coilovers. How hard is it to adjust the height?
      06-11-2020, 09:58 PM   #15
DreamerJoe
not hard, there are 2 nuts on the coilover, one that locks and one that sets the height. loosen the locking one and it allows you to spin the height adjusting one up or down, amd then adjust the locking one again against the height nut. only thing time consuming is getting the car on a jack and removing the tire
f30post
