Bimmerpost
4 Series
Technical Topics DIYs and Coding Discussions Connectors for retrofitting OEM parts
      06-03-2020, 04:54 PM   #1
hottroc
45
Drives: BMW 330e
Hi, so where can I buy connectors for wiring in original BMW parts? Preferably in the UK.
      06-04-2020, 08:04 AM   #2
Lo2
Hong Kong
62
Drives: .
What are you trying to wire in?
      06-04-2020, 08:06 AM   #3
hottroc
45
Drives: BMW 330e
I have several things, interior items. For example a passenger microphone, wireless charging pad etc.
      06-04-2020, 04:19 PM   #4
mrgicm
mrgicm's Avatar
441
Drives: BMW M
Search newtis.info for connector name/location/wireing than search in realoem.com for partnumber and order from dealer by part number.
      06-04-2020, 04:40 PM   #5
hottroc
45
Drives: BMW 330e
Unfortunately that method does not seem to work for connectors.
Example:
In newtis the connector appears to be E405*1B described as "6-pin connector"
In realoem nothing comes up searching for E405*1B. Searching for 6-pin connector brings up a very poor res picture of the entire wiring loom of the car, impossible to make out anything. Looking through the list below I find several possibilities, such as 61139242495 but when I click on it there is no individual picture for me to check. And it seems to be related to something completely different (seat-belt retractor?)
Any other suggestions? Are they standard connectors in any sense or BMW specific?
[EDIT - So I found one of the connectors on newtis, see pic attached, but none of the numbers appearing in the diagram appear anywhere on realoem]
[EDIT2 - And that info on newtis is itself wrong anyway. Even though I put in the exact car and took the number from the wiring diagram. But as seen in the diagram below, that shows as a 4-pin connector...it's definitely needing to be a 6-pin connector. That's why it's essential to be able to see a photo of the part]
      06-06-2020, 11:23 AM   #6
mrgicm
mrgicm's Avatar
441
Drives: BMW M
For 100% information you need latest ETK. Newtis can serve you as a guide.
      06-06-2020, 12:12 PM   #7
hottroc
45
Drives: BMW 330e
Sorry, what's ETK? And where do I get it?
g20
