BMW X5
      05-30-2020, 07:26 PM   #1
M50iX5
17
Drives: 2016 X6 2020 X5 M50i
Tire pressure
Have 22inch summer Contis dealer installed on my M50i checked pressure today and it reads 40psi on front and backs. What is optimal pressure ? I mostly drive solo but occasionally with wife and 7 yr old.
      05-30-2020, 10:33 PM   #2
X5 45e
1091
Drives: BMW X5 45e
In Europe it is printed on a badge in the inside of your drivers door and it is included in the tire pressure monitor. If you activate TPM it will show the actual and optimal pressure if you have entered the correct wheel size.
We use different metrics so can't help you with the figures
It is also written in the manual. It is not included in the app version. It refers to the badge in the door.
      05-31-2020, 05:27 AM   #3
M50iX5
17
Thanks yes I did see that but my understanding was that those pressure numbers are for maximum load as I am the primary driver was wondering if there's a more optimal number
      05-31-2020, 06:43 AM   #4
Auricom
Auricom's Avatar
Drives: 2020 X5 xDrive40i M Sport
Found earlier and relevant questions on 22" and PSI:
Correct Tire Pressure https://g05.bimmerpost.com/forums/sh....php?t=1668176
Thread above for 22", 38-39F/45R for 5 passengers. You can lower depending on your comfort or less than 5 passenger load.
For example, I'm running 33F/41R on 20" A/S. I wouldn't run 22" less than 36F/42R or equal pressures front and back.
Current BMWs - '20 X5 xDrive40i M Sport, '20 BMW M550i | Past BMWs - '03 E39 540iT M Sport, '06 E53 4.8is, '11 E70 M Sport LCI
      05-31-2020, 11:40 AM   #5
X5 45e
1091
Drives: BMW X5 45e
It shows two values. One for driver alone and one for driver with passengers and luggage
      05-31-2020, 04:43 PM   #6
M50iX5
17
Thanks doesn't show on my M50i maybe it's because it's a Canada based vehicle? Does anyone have a picture they could post showing the different pressure options for the 22s
      05-31-2020, 08:30 PM   #7
Paladin1
Paladin1's Avatar
Drives: 2022 iX xDrive50, DGM
Found this (I assume maximum cold inflation loaded):
Name:  SmartSelect_20200531-202907_Samsung Internet.jpg
      06-01-2020, 03:13 AM   #8
X5 45e
1091
Drives: BMW X5 45e
This is the badge in my car. The lower values printed in italics are psi.
Three figures= normal
Five = fully loaded
These are the values for the 45e which has a 250 kg battery on the rear axel. I don't know if they would advise a different pressure for other engines.
So your 40 psi seems quite high if you are driving alone on the 22 inch summers.
I also added pictures from Idrive. I can chose the type of tires (bandensoort) winter vs summer and load (belading). And it displays this in the picture (vereiste druk) in this case 2.3 bar in front and 2.5 in the back
Strange that the car doesn't follow the advise on the badge by the way. Both 0.1 bar higher.
      06-01-2020, 07:54 AM   #9
Paladin1
Paladin1's Avatar
Recommended pressures are usually listed on a sticker inside the driver's side door. If not there, then the owners manual will have a chart, and BMW helpfully shows a chart in iDrive for OEM tires for a specific vehicle. Nothing wrong with using the loaded pressure recommendation as a starting point (you'll get better mileage, but a potentially harsher ride), and adjust down from there - underinflation is worse than oveinflation with respect to tire life, fuel economy, braking or acceleration. That's what I use, because sometimes the car is loaded, sometimes it's not, and my label doesn't even have a partially-loaded pressure recommendation:
Just never use the maximum inflation pressure listed on the sidewall as a guide - you're in dangerous territory if you're at or above that.
      06-01-2020, 08:40 AM   #10
X5 45e
1091
Drives: BMW X5 45e
Attachment 2326831
Looks like your values match the unloaded ones in my sticker.
Do you live in Canada? Or do all cars in the us have English and French stickers?
      06-01-2020, 08:54 AM   #11
X5 45e
1091
Drives: BMW X5 45e
On my sticker you would need 35 psi in front and 38 psi in the rear for 22 inch driving alone. If you are ok with the comfort it should be fine if not you can lower it a bit.
      06-01-2020, 09:22 AM   #12
Paladin1
Paladin1's Avatar
Nope, US. I think the default is bilingual for NA. The values for the door stickers are for maximum load if no other values are indicated in the US also
      06-01-2020, 09:57 AM   #13
X5 45e
1091
Drives: BMW X5 45e
The values on your sticker are the ones that are advised for a normally loaded vehicle on my sticker. The values for fully loaded 275 20 inch are higher: 42 and 49 psi.
I also have 20 inches but in Europe they are staggered 275 and 305. For me the best choose. I like the look and the comfort is good.
      06-01-2020, 10:32 AM   #14
Paladin1
Paladin1's Avatar
Interesting - this is the pertinent regulatory reference from the NTHSA in the US for labeling requirements:
Paragraph S4.3 of FMVSS No. 110
requires manufacturers to affix a placard
to each passenger car’s glove
compartment door or an equally
accessible location showing the
vehicle’s capacity weight, designated
seating capacity, the manufacturer’s
recommended cold tire inflation
pressure for maximum loaded vehicle
weight,
the manufacturer’s
recommended tire size designation, and,
for a vehicle equipped with a non-
pneumatic spare tire assembly, the non-
pneumatic identification code required
by FMVSS No. 129, New Non-
Pneumatic Tires for Passenger Cars.
Most US cars manufactured since 2003 have the placard located on the driver's side door pillar, but it can be located elsewhere. Sounds like European regulatory requirements may be different, but as long as ranges are within manufacturing tolerances shouldn't matter.
      06-01-2020, 10:52 AM   #15
X5 45e
1091
Drives: BMW X5 45e
weight,
the manufacturer’s
The picture I posted is the sticker on my drivers door. But it looks different than yours indeed.
The only thing is that I have a 45e which is a heavier car. Maybe that can explain the difference. I don't know.
I can't explain the difference either.
      06-01-2020, 12:29 PM   #16
Paladin1
Paladin1's Avatar
It is confusing! Also noted that some of the recommended pressures on your sticker (I couldn't decipher whether for 20, 21 or 22 inch tires) exceed the max pressure recommended on the sidewall of my tires, but mine are squared vs staggered (20" Bridgestone, 44 psi). Probably the best bet for the X5 is to go by the OEM pressures for specific tires listed in iDrive in the TPM Reset menu.
      06-01-2020, 12:59 PM   #17
X5 45e
1091
Drives: BMW X5 45e
It indicates indeed that for your tires, fully loaded 49 psi is advised for the back tires.
The sticker is a bit hard to read.
      06-01-2020, 02:38 PM   #18
Paladin1
Paladin1's Avatar
Thanks! Just checked and the max on the sidewall is 50psi, so just in range. Must be the additional weight on the 45e....
      06-12-2020, 12:46 PM   #19
UltraDave
UltraDave's Avatar
127
Drives: 2020 BMW X5 M50i
My M50i also has the 22 inch with staggered pressures. I think it recommended 39 front and 44 rear in the idrive display menu. First car I ever owned that suggests different pressures for front and rear.
xbimmers
