Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Help please !!! codes
      05-30-2020, 03:16 PM   #1
dyllan12
13
Drives: BMW e92 335i
I'm getting code 30FE saying "turbocharger , charge air pressure to high " when I WOT ( Limp Mode)
I'm on MHd stage 2+ e50 FBO
Tune up done
Vacuum Lines changes
19,000 miles on Turbos
never changed boost solenoid ... Do y'all think that's probably the issue
      05-30-2020, 04:01 PM   #2
Saif2018
973
Drives: E90 335i
Tune up done
Log?
Have a read through this thread...
https://www.e90post.com/forums/showthread.php?t=1149162
      06-06-2020, 05:27 PM   #3
dyllan12
13
I am so late sorry , but this is the log guys
I'm on MHD stage 2+ e50. again
https://datazap.me/u/dyllan012/log-1...&data=3-22
btw all the codes again are
3100- Boost control Deactivate
30FE- TurboCharge, charge air pressure to high
2c77 Oxygen sensor after catalytic converters signal
(came up)
      06-06-2020, 09:26 PM   #4
feuer
feuer's Avatar
Drives: wife crazy!
Haven’t seen your log but maybe you need to modify the Tmap sensor.
      06-07-2020, 11:13 AM   #5
dyllan12
13
This is another log that i just did, I'll really appreciate if someone could take a look at it , I'm still learning how to read logs thou
I wanna make sure if the wastegate are looking fine , I'm trying to cancel out what could cause these codes , I just orders boost selenoids too ...
https://datazap.me/u/dyllan012/log-1...&data=3-21
      06-07-2020, 12:32 PM   #6
turbohugh
ASCMA General
turbohugh's Avatar
51
Drives: E90-N54 <>E36 328Vert
https://datazap.me/u/dyllan012/log-1...og=0&data=3-21
Did you test your old boost solenoids ? With a mightyvac it's easy. Test, confirm, then spend .. [my motto, but I'm a 'poor' ] my Jeep emptied every pocket.
      06-07-2020, 01:16 PM   #7
dyllan12
13
I didn't know you could test it , ima look into it , I'm hoping that's just what it is
      06-08-2020, 11:43 AM   #8
dyllan12
13
bump .. have anyone else experience a problem like this or know someone who has?
      06-08-2020, 02:19 PM   #9
Saif2018
973
Drives: E90 335i
Have you checked your O2 sensors?
Hopefully your solenoids fix overboosting issue.
Also do you have inlets?
      06-12-2020, 02:11 PM   #10
dyllan12
13
no inlets and hopefully the solenoid do resolve this issue
      06-13-2020, 10:29 AM   #11
Saif2018
973
Drives: E90 335i
Post back and let us know.
      06-18-2020, 10:14 PM   #12
Occ224
13
Drives: 2007 E92 328i
Im having the exact same codes except the o2 sensor. I just upgraded downpipes and uped to stage 2+ mhd v9
      06-25-2020, 11:43 PM   #13
dyllan12
13
Giving update to this thread , even thou there's like 3 of the same thread this week ...
UPDATE .. the boost solenoid didn't fix my issue , I'm going to purchase boost pressure sensor
btw my turbo are new 20k+ miles
