Flashing MHD tune today and have a couple questions.
05-30-2020, 12:26 PM | #1 |
92
Rep 281
1) Should I go with the V.9 beta or V.8 maps?
2) Can I do stage 2+ with DP's but no FMIC? I ordered a VRSF FMIC and it will ship mid June. Will it be okay till then or should I just get stage 2 and then purchase the 2+ map in a few weeks when I get the FMIC? 3) When using the battery charger should it be in boost or trickle mode? 4) For the "OEM/catted DP's" I do not check this since I'm using catless DPs correct. 5) What should I set "coolant target at? 6) Linear throttle mapping good or not? |
05-30-2020, 12:27 PM | #2 |
92
Rep 281
Sorry for all the questions, I'm just reading through the N54 flasher user guide and am feeling a bit overwhelmed. I've never installed a tune before and I want to make sure I do it right.
05-30-2020, 01:40 PM | #3 |
604
Rep 483
Im running stage 1+ v9 and i havent had any issues. Power is smooth and comes on strong.
Correct about oem/catted dp option. It just makes it to where your car wont throw cat efficiency codes & check engine light (same thing as what a dp fix would do but in a different way i think) My coolant target is set to sport and havent had any issues. Track is used for drag strip or at the... track. As it puts the cooling system in i guess you could say full blast so keep the car as cool as possible before runs at the strip or on the track. Probably wouldnt use for street use Linear throttle mapping will just smooth out the power. I havent used it much but i think it kinda drove like an NA car and reduced low end torque. Probably would be fine having the charger set to trickle mode If im wrong about any of this/something needs a correction, anyone is free to correct me
Speedtech Top Mount 6766 2009 335i
VF Supercharged 2003 540i msport https://www.instagram.com/schwarz.e92/ |
Slim41591.50 |
05-30-2020, 02:08 PM | #4 |
91
Rep 188
MHD recommends FMIC for 2+ so I would not run that until you get that on just run 2 for now and the switch it only takes 2 minutes to switch the map in the future. I run the V9 2+ map and love it the power is great and super smooth. Keep the stock DP box unchecked, as for the throttle I haven't tried linear so can't speak on which is better.
Slim41591.50 |
05-30-2020, 03:07 PM | #5 | |
973
Rep 3,219
Either use V7.1 maps or V9 beta. 2) bad idea to go stage 2+ without FMIC, your stock intercooler will rapidly heat soak, high IATs and you will loose power. Stage 2 map pack comes with 2+ maps. 3) a trickle charger with 8amp or more should be fine. 5) Sport coolant target recommend by MHD for every day driving. Some people have reported higher fuel consumption as a result though. 6) linear throttle mapping not recommended for automatic transmissions. |
05-30-2020, 03:55 PM | #7 | |
875
Rep 5,457
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
05-30-2020, 04:16 PM | #10 |
92
Rep 281
I'm trying to figure out how to turn off my halo DRL's before I flash. People say put key fob in, press start. And for me then my lights come one. There's no way I can see that turns off the halo's. Is this okay to leave on?
05-30-2020, 05:58 PM | #11 |
641
Rep 1,245
If it's hooked to a battery charger. It does not matter
2009 335i xDrive AT / 177k+ miles
PSP 750ic / Fuel-It! Stage 1 / BMS CP / Sutphin Tuning / RFP E50 11.61 @ 117.5 New setup; Covid 19Ts on RFP 93 + ARM inlets, dp, VTT cp and PSP outlets |
05-30-2020, 06:02 PM | #12 | |
1905
Rep 6,968
Drives: 2007 Black/Black 335i e90
Use Version 8 for now. Beta is an unrefined product. Refined enough that it probably won't cause problems but why bother. Wait until it's not listed at "beta" 2) Can I do stage 2+ with DP's but no FMIC? I ordered a VRSF FMIC and it will ship mid June. Will it be okay till then or should I just get stage 2 and then purchase the 2+ map in a few weeks when I get the FMIC? No. You should do stage 2. Stage 2+ is for an upgraded FMIC & Downpipes. 3) When using the battery charger should it be in boost or trickle mode? Trickle mode - make sure your battery charger can maintain 14.5 volts; the DME is very sensitive. A 30amp or better battery charger/maintainer can do this no problem. Turn off the lights, radio, & heat off. Do not open the doors, windows or anything when flashing... 4) For the "OEM/catted DP's" I do not check this since I'm using catless DPs correct. Correct 5) What should I set "coolant target at? Sport mode works nicely... 6) Linear throttle mapping good or not? Not a fan of it |
05-30-2020, 06:05 PM | #13 | |
1069
Rep 945
Drives: e92 335i, f22 m235i, e30 325is
It takes time to adjust to though, the car does feel slower when you're used to the aggressive 80% @ 40% stock throttle map. But it makes it so much easier to take off smoothly and modulate the throttle finely when you need to |
type-dRew641.00 |
05-30-2020, 07:52 PM | #14 | |
973
Rep 3,219
You can turn it off by turning the headlight knob to the 12 o'clock position, straight up. For map flashing after MHD has been initially installed, you should turn ac, off, and headlights off completely as above. This usually takes about 2 mins max and does not need a charger. |
type-dRew641.00 |
05-30-2020, 07:55 PM | #15 | |
973
Rep 3,219
Using linear throttle on a Automatic transmission makes the car feel laggy. Stock throttle is already easy to modulate anyway. |
05-30-2020, 09:03 PM | #16 | |
1069
Rep 945
When I first flashed linear, it was a bit disappointing, not gonna lie. The car felt anemic but idk if i'm just used to it, but I really am liking how the car goes exactly how I want it to now. Especially those times when coming to a stop but before getting there, the light changes or traffic speeds up. It was just really touchy even if I barely tapped it |
type-dRew641.00 |
05-30-2020, 09:21 PM | #18 | |
1905
Rep 6,968
When you play around with ISTA, you will learn that this program requires the battery to be on a trickle charger that keeps the battery at 14.50 at all times. |
05-30-2020, 10:47 PM | #19 |
721
Rep 946
Haven't tried V7 map yet. Only used V8 and V9 (currently using) why do you prefer V7 over V9? Just wondering if I should switch over.
07 E92 335i 6MT, MMP inlets, DCI, VRSF 7.5 competition intercooler, VRSF catless downpipes, VRSF chargepipe, 335is clutch, Vader Solutions stage 2 LPFP, MHD stage 2+, Hawk HPS 5.0 pads, R1 Concepts drilled slotted rotors, TSW Nurburgring 19x8 19x9.5
05-31-2020, 11:56 AM | #20 |
92
Rep 281
Went great, and car is fast as hell now. That first time out after a tune is a magical experience. Had my heart racing and palms sweating in a good way. Think I'll turn the burble down though. I have it set to 1 second, medium at 2.8K RPM but it seems a bit loud and excessive but that's just my personal taste.
Something I did notice was that I have power loss in high RPM range of 2nd and third gears. Maybe it would also happen in 4th or 5th but I never got that far as there's not many places to drive fast in San Francisco. This didn't happen all the time but when it did, the car would be flying and then felt all of the sudden like I was driving up a steep hill. Not sure how else to describe it. I purchased the monitor, so I'm gonna go out and log some data to bring back to you guys. I also read that you should change your spark plugs when tuning. I didn't do it yet but I have a set of 1-step colder plugs to install. Not sure if that could be related to the issue. Edit* I went with the V.9 beta map stage 2 for MT and 91 pump gas. |
05-31-2020, 12:32 PM | #21 |
82
Rep 227
I'm only speculating here without your logs, but it could likely be your IATs. My car would do the same before I got an intercooler.
2011 E92 335i 6MT | MHD | AA FMIC | AR Design DP | ER CP | PE | AutoSolutions SSK | SouthBend Stg3 | MFactory SMFW | Bilstein B14 | M3 Arms | -2.75° camber |
2020 Porsche Macan S PASM |
05-31-2020, 02:37 PM | #22 |
721
Rep 946
If its dying off around 5500-6000rpm that is completely normal as that's where the stock turbos die off. It's much less noticeable until you tune the car. Simply shift sooner and it shouldn't be a problem.
