05-30-2020, 12:16 AM | #1 |
35
Rep 130
340mm calipers in rear
Is it possible to mount a set of the 340mm calipers on the rear of the car?
If I bought the larger 370Msport calipers/rotors and put them on the front, could I mount the 340mm calipers and rotors on the rear? ~N55 |
05-30-2020, 11:10 AM | #2 |
993
Rep 1,934
With enough money, time, and engineering, yes. Why should you when it's cheaper to buy the 345mm 2piston brembo parts. Bmw has already done the hard part for you. Thread.
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
imperfectluck426.50 sgovind77.50 |
05-30-2020, 09:10 PM | #3 |
35
Rep 130
Good point. Never thought about it, I thought bout 4 piston in the rear, but I suppose 2 piston and slightly larger mm M sport could be just as good.
05-31-2020, 01:42 AM | #4 | |
4528
Rep 5,392
Drives: 2015 BMW 335i x-Drive Auto
In addition, inside the rotor hat, rotors have to match the size of the handbrake installed on your car, either earlier 160mm or later 185mm. See photo for how to determine. Most rotors are 185mm. |
