05-29-2020, 10:13 AM | #1 |
48
Rep 206
H&R coils and wheel spacers
I've bought H&R SS coils and i wanna buy wheel spacers. How many mm am I actually shopping for? Do i lower the car first and then measure? Thanks guys!
2016 BMW 435i M-Sport
- JB4 and MHD - xHP - Injen intake - Active Autowerke intercooler - Active Autowerke charge pipe - AWE catback *** I want more!!!*** |
05-29-2020, 11:07 AM | #2 |
810
Rep 919
Drives: F30 328d Sport Line
The spacer width depends on your wheel and tire setup. If your wheels and tires are stock specs, 10mm in the front and 15mm in the rear is a popular option. You'll also need extended lug bolts (unless you're doing / have done the wheel stud conversion). I have 10mm front and 15mm rear spacers on stock wheels and they sit flush with the fenders. I recently did the wheel stud conversion and am selling the extended lugs if you're in need of some.
05-29-2020, 11:12 AM | #3 | |
48
Rep 206
05-29-2020, 11:22 AM | #4 |
810
Rep 919
No rubbing at all, not a single time. My car has the M-Sport suspension and hasn't been lowered.
05-29-2020, 11:28 AM | #5 | |
48
Rep 206
Blank
haagm58809.50 |
05-29-2020, 11:33 AM | #6 | |
810
Rep 919
If you go with a more aggressive setup and run into rubbing issues, you could roll your fenders. Here is an example: |
05-29-2020, 12:02 PM | #7 | |
3080
Rep 4,331
plumb a straight edge from the fenderlip and measure the distance to the part of the tire you want it to be flush with. that distance will be the spacer thickness you require. |
haagm58809.50 |
05-29-2020, 12:07 PM | #8 | ||
48
Rep 206
alohasurftoad3079.50 |
