Bimmerpost
4 Series
Technical Topics DIYs and Coding Discussions Instrument cluster 330kmh to 260 kmh coding
      05-26-2020, 02:34 AM   #1
sztmek
21
Drives: BMW 3 G20
Hi mates! As in the topic is possible to code the instrument cluster from 330 to 260 kmh . My alpina cluster is for me not readable , via bimmercode
      05-26-2020, 06:32 AM   #2
Watzek
Watzek's Avatar
8
Drives: BMW G20
It is possible to activate M layout with 260 km/h instead of originally 330km/h with e-sys.
In KOMBI4 unit search for AG_MPA_MSP_VIEW parameter and set to "mpa_ansicht_260_skala"
Appreciate 3
VipinLJ1941.50
RichardM133.00
      05-29-2020, 03:25 AM   #3
sztmek
21
Drives: BMW 3 G20
Thanks a lot! But i have only bimmercode , the same formula works in this option?
      05-29-2020, 08:53 AM   #4
PunkSinatra
78
Drives: Alpina D5S
I would like to ask it the other way. Is it possible to code the original cluster from 260kmh to 330 kmh? At the moment I'm using alpina Displays, but would like to use the original.
      05-29-2020, 12:40 PM   #5
PunkSinatra
78
Drives: Alpina D5S
I've done it. It's just the same way of this thread, just changed the scale to 330.
      06-10-2020, 03:28 PM   #6
A6bullet
Germany
337
Drives: 2020 330i Msport
Done on mine. Kept the original BMW faces
E36 318ti
E46 320i
E82 135i
F87 M2
G20 330i
      08-15-2020, 03:56 AM   #7
Joedeejay
64
Drives: BMW G20
To dig this one up. So getting the M Font is great thanks
I do prefer the full M Layout, the changes to the oil temp fuel gauge etc. Anyway to code them through or is that restricted to the M Layout? As much as I prefer it, the 330 scale is a tad extreme for mine hah
Also any way to change font of the HUD too? Tried flicking through expert mode but nothing jumped out at me for it
      09-16-2020, 02:29 PM   #8
rockblock
rockblock's Avatar
57
Drives: 2023 M240 xDrive
Why doesn't the RPM show 8 (x1000)?...the US version shows 200 mph & 8 RPMs
      09-22-2020, 02:10 AM   #9
A6bullet
Germany
337
So I didnt change the actual layout of the dash. I went in and only changed the scala on it from 260 to 330. It also changes the font which I really like. 330kmh is a bit extreme but I do really like the font.
E36 318ti
E46 320i
E82 135i
F87 M2
G20 330i
      09-22-2020, 08:27 AM   #10
rockblock
rockblock's Avatar
57
Thx, a few more questions:
* Is there a way to also change the scale for the RPM?
* is 330 the only option, or can you do say 320 with an even scale rather than odd?
* Can you change the scale increment?
* Can you change the font?
Thx
      10-01-2020, 09:38 AM   #11
A6bullet
Germany
337
Thx
1. Not sure have tried to change RPM
2. 260 and 330 are the only default options. Everything is changeable but idk on that part.
3. Not that I saw
4. Again maybe, but it seems its tied to what scale you choose, from the presets.
I would recommend just sticking with the regular display and then changing the scale.
E36 318ti
E46 320i
E82 135i
F87 M2
G20 330i
      10-01-2020, 09:44 AM   #12
rockblock
rockblock's Avatar
57
Thanks for the response...one thing I've noticed is that with the updated 330kph display, the driving modes and gears have disappeared (S1, S2...M1, M2, etc)...only shows "D" - any way to bring those back?...even in manual mode I don't know what gear I'm in
      10-01-2020, 09:48 AM   #13
A6bullet
Germany
337
Oh interesting, I still have gears showing on mine. I really wish I could help you man, but im just a lay person and don't know much about all the happenings behind the scenes when coding. Have you tried reverting to a back up and re coding?
E36 318ti
E46 320i
E82 135i
F87 M2
G20 330i
      10-01-2020, 09:58 AM   #14
rockblock
rockblock's Avatar
57
hmmm....doesn't work - I thought there might be a setting in iDrive or signal lever that I might have missed - thx anyway
      10-01-2020, 02:44 PM   #15
rockblock
rockblock's Avatar
57
Alpina mode on the other hand is BRILLIANT !!!...great design, wonderful fonts, 340 max kph and all modes show
If there was a way to replicate the Alpina design with to an "M" or "M Performance" logo (and possible red/amber contrast instead of blue) that would be a perfect score for me
      10-01-2020, 05:19 PM   #16
rockblock
rockblock's Avatar
57
Well I found a way it's supposed to do it, but it doesn't work
In Expert mode, if you go to DKOMBI4 / section 3001 / LOGO_SCHRIFTZUG you will have 20+ options to choose from, including the M logo...however, no matter which other option I choose, it will just remove the Alpina logo, but not display any of the selected ones...choosing Alpina will revert back....so the option is there, but doesn't seem to work - only logo you can have is either Alpina or nothing
anyone tried this?
      10-01-2020, 09:29 PM   #17
VipinLJ
Petrolhead
VipinLJ's Avatar
Drives: ‘20 330i,‘16 X3,‘18 SQ5,‘17 A7
anyone tried this?
Yup. It's either the alpine logo or nothing with the alpine cluster. You can't out an M/M340i logo in its place.
Current:
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
ingmv23.50
      10-02-2020, 11:58 AM   #18
rockblock
rockblock's Avatar
57
Yes, unfortunately I got this response from BimmerCode support:
"The M display style is not fully compatible with regular cars and there is no way to fix display of driving modes unfortunately. The other things can not be tweaked also
Only the Alpina logos work with the Alpina layout unfortunately"
Right now it appears the 5/7 series and some X get to enjoy
      11-01-2020, 04:36 PM   #19
thelmers
Netherlands
Drives: BMW M340i xDrive Touring
You are probably also missing things on the HUD in M mode. You can use the original layout and set DKOMBI -> ag_mpa_msp_view to 330. Then all the driving mode keep working I think.
      11-02-2020, 08:50 AM   #20
jeegunkim
jeegunkim's Avatar
328
Drives: 2020 330i xDrive, 2023 M3CX
Was this done through Bimmercode? Mind sharing how it was done?
2020 MG 330i xDrive M Sport
2023 AR M3 Competition M xDrive
      11-03-2020, 06:23 AM   #21
A6bullet
Germany
337
Sure:
Is all you need to do
E36 318ti
E46 320i
E82 135i
F87 M2
G20 330i
      11-03-2020, 11:33 AM   #22
jeegunkim
jeegunkim's Avatar
328
Sure:
Worked like a charm - thank you!
Any idea how to get the M startup animation in live cockpit?
g20
