05-23-2020, 12:56 PM | #1 |
GUNS N ROSES
18
Rep 2
I added Equalizer Settings on my G20
Finally after a lot of try and error here is my first post and contribution to this forum after I purchased my g20 last year I noticed the lack of equalizer settings on my Base 330i I was thinking no problem I can add one WRONG ! Well after going to numerous places getting quotes and getting non sense amounts from 2k to 4K you can do it because of the ram radio thanks to bimmercode and research on expert mode here is the procedure go to bimmercode to HU MGU HEADUNIT then expert mode from there pic 3002 then look for AUDIO-SYSTEM then change the parameters from alev2-Ram to alev4-Ram code and you got a free working Bowersand Wilkins settings and working equalizer enjoy,
8
greekcs773.00 Bimmer_73NL10.00 EXE462100.00 VipinLJ1941.50 pneumodoc233.00 CrownRoyal79284.00 Fpangalos46.00 singhinho1.50 |
05-23-2020, 01:02 PM | #3 |
773
Rep 1,113
Nice find!
2003 11/02 Steel Gray Metallic on Red M3 - SMGII - VF570 - SUPERSPRINT - KW - BBS - CSL ROOF SOLD
2015 09/14 Alpine White on Red 435i xDrive MPPK - Expensive black vinyl with special lettering. SOLD 2020 12/19 Mineral Gray Metallic on Black Vinyl interior M340i xDrive |
05-25-2020, 09:39 AM | #8 |
21
Rep 36
I dont know how this feature has influence for stock Audio system , but bower Wilkins settting in “ concert” change my audio settings to different level. Bass and treble are much much higher, sounds magic. Of course I added eq settings like V sounds and increased surround level to max.
05-25-2020, 12:08 PM | #9 | |
15
Rep 48
EQ settings seems to be working pretty good on stock system. I wasn't expecting anything from the sound profiles since I have the stock system. |
05-25-2020, 12:57 PM | #11 |
21
Rep 36
Yes i have harman kardon audio. The surround settings is much much better so now I feel voice of singer completely different as on the stage .
05-27-2020, 06:07 AM | #13 |
15
Rep 48
05-27-2020, 12:33 PM | #14 | |
83
Rep 157
05-27-2020, 01:06 PM | #15 |
233
Rep 423
I contacted bavsound (since I have stage 1 plus ghost woofers) and they suggested the following settings. I don’t have logic 7 as an option, but will try the rest.
Bass - FLAT Treb - FLAT Logic 7 - ON Balance FLAT Fader FLAT (keeping it flat after speakers break in give you the best reproduction of the music, although I did have it "+1 Fader" originally to create more imaging while keeping the volume down) +2 100HZ -3 200HZ -1 500HZ -3 1KHZ -1 2KHZ -2 5KHZ -1 10KHZ |
05-28-2020, 07:43 PM | #16 |
GUNS N ROSES
18
Rep 2
About the settings on my G20
Yes I also have aftermarket speakers bavsound (the best ) and I am glad that they share some settings for this mod already added a aftermarket JL AUDIO WOOFER mono to the 2 woofers in the bottom of the seats and let me tell you I used to sound really flat only using the treble bass and fader lol I know it’s sad but I been playing with it a bit and it’s sound amazing so I can really tell that the mod it’s not just (cosmetic) there is a setting to make it louder on expert since the number set on Max Vol ( in German ) it’s set on 35 I may play with it a bit this weekend it will be my next frontier 😁 since bavsound had not released a amp for us yet
05-28-2020, 07:46 PM | #17 |
Petrolhead
1942
Rep 3,521
I tried it on the non-HK HiFi system in my car and couldn't notice a difference with the presets (movie theatre, concert etc). With the equalizer, I noticed a difference only when I changed the two on the ends (bass and treble settings) and none in the middle (100Hz, 200, 500 etc). I tested it on SiriusXM.
Current:
2020 BMW 330i xDrive 2018 Audi SQ5 Prestige 2017 Audi A7 Prestige |
G20agba4.50 |
06-04-2020, 09:15 AM | #18 | |
45
Rep 243
06-04-2020, 11:24 AM | #19 |
Rep 28
Do you have to delete the original Bimmercode app to use the beta mode?
06-04-2020, 02:40 PM | #21 |
Rep 28
06-04-2020, 07:54 PM | #22 |
Petrolhead
1942
Rep 3,521
From how it works in my car, yes. It's purely cosmetic. I totally forgot that I had coded that. I'll revert it back to stock.
Current:
