Coolant Hose Connector?
05-22-2020, 08:18 PM | #1 |
1905
Rep 6,968
Drives: 2007 Black/Black 335i e90
I have a small leak at the connection of the lower coolant hose, on the coolant expansion tank. I've replaced the O-ring a couple of times w/ out much success. The coolant hose is actually a series of connections that run down to the subframe and over to the heater hose connectors. I really want to avoid $125.00 for a new set of pipes and then having the joy of replacing it...
I think the connector is shot. It's original to the car at 174,000 miles. After replacing the coolant flange to the OFHG a couple of months ago, it gave me the idea of just replacing the connector. The hose is fine. Anyone ever do this? Where do I get just a connector? Please Advise.... |
05-22-2020, 09:14 PM | #2 |
4276
Rep 9,209
I might have that whole line. I will check and let you know.
mweisdorfer1904.50 |
05-22-2020, 11:05 PM | #3 |
399
Rep 1,579
It is annoying that that hose does not have an aftermarket alternative. All of the 15 other hoses can be purchased more affordably with quality aftermarket options. You could put some RTV on the o-ring area. Believe it or not, that is one of the easier hoses to replace.
05-23-2020, 12:12 PM | #4 | |
1905
Rep 6,968
If I could get a used one for $40.00, I'd just take the connector out & replace it!!! |
05-23-2020, 05:42 PM | #6 |
4276
Rep 9,209
Deal. I will send you my info. Or not. Unless you empty your inbox lol
05-23-2020, 06:33 PM | #8 | |
1905
Rep 6,968
I'm not gonna replace an entire hose that length with a used hose. No offense. If I did that, I'd buy it new. I really don't want to replace the hose at all. I just want to replace the connector. If and when the hose goes, that's when I'll replace it with a new one. The radiator hoses on the e90 are pretty stout IMO. I sometimes laugh when I read about guys on this forum wanting to proactively replace the radiator hoses, and they are 125,000 miles in or something 😂 O-rings yes, but that's all you really need to do. How much do you want for it? I cleared out my inbox |
smass398.50 |
05-23-2020, 06:45 PM | #9 | |
4276
Rep 9,209
05-24-2020, 05:59 AM | #10 |
17367
Rep 18,768
Maybe the leak is on the reservoir tank side?
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission. "Yeah, but NO ONE puts an automatic trans shift knob on a manual transmission."
05-24-2020, 08:27 AM | #11 |
1905
Rep 6,968
05-24-2020, 08:50 AM | #12 | |
17367
Rep 18,768
Why an open hose with hose clamp doesn't work for BMW, I'll never understand. Re-invention of a part to address a problem that was solved 100 years ago, is just a German engineering exercise. As former manufacturing engineer, I just don't see the manufacturing assembly process savings vs. the expense and complexity of manufacturing injection molded critical-dimensioned parts. Apologies for the rant.
05-26-2020, 08:03 PM | #14 | |
4276
Rep 9,209
05-26-2020, 08:06 PM | #15 | ||
1905
Rep 6,968
05-26-2020, 08:23 PM | #16 |
17367
Rep 18,768
Me too. I posted a DIY in 2014 for replacement of all 9 N52 coolant hoses and said the same thing at the time.
08-13-2020, 06:33 PM | #18 |
Rep 1
I know this is late, but want to post this for those with a similar coolant leak involving the heater core supply hose connected to the upper radiator hose. I believe you are addressing a leak at the 45 degree angled quick connector on the heater hose at the upper radiator hose. I cut off the connector and tried to re-use, however, I found that this was futile because the connector does not have a "bulbed" end to securely hold a screw type hose clamp. I purchased a new heater core supply hose (BMW HVAC Heater Hose - Genuine BMW 64216983858 for an E90 335i, a 328i is a different part #) from FCPEuro, $40, and replaced the entire hose, which turned out to be a much easier job than cutting off and attempting to re-use the connector.
feuer4275.50 |
