Base stereo, bse EQ - to recode or not recode
05-20-2020, 05:29 AM | #1 |
11
Rep 54
Apologies if this has been asked befoe. I've searched (and searched), but there is a lot of conflicting info and much of it is 10 years old.
1) Does the base speaker sysyem (ie not Hifi or L7/HK) EQ stay the same throughout the volume (and vehicle speed) range or does it change? I have an Audison AP5.9 that De-EQs but ofc it only does it at a given volume, thats a major issue if the EQ changes at differing volumes (or speed). 2) I have CIC with basic nav. Could someone please point me towards a thread or guide on using ncsexpert or one of the phone apps to recode to HiFi. Or even the codes needed and I can learn the rest. 3) Can just the EQ be removed whilst retaining high level outputs (thinking of noise/hiss). 4) For those who have recoded to hifi, where did you take the amp/dsp remote turn on power wire from? Thanks in advance. |
06-01-2020, 05:02 PM | #4 |
11
Rep 54
re the auto turn on, I don't think that the HiFi coded HU have enough voltage to trigger the auto turn on. Both my units (Audison 5.9 and Helix P6) only do it on high level. Considering the risk of low volume calls and PDC gongs, I think I'll stay with base and just use REW and the P6 input eq to de-eq. Now I have to figure out whats wrong with my current test sweep (REW and external DAC connected to line outs of an un-equalised Audison DSP). Its very different from the freqency plot in your 1st link, giving me a 40dB rise between 20Hz and 20kHz.....really starting to hate this audio system. |
06-01-2020, 05:57 PM | #5 |
1911
Rep 13,104
The 12 volt line on a Hi Fi harness equiped car to the amp
probably does not even come from the Head Unit as it is used to power the amp. On that particualr setup the Technic Harness supply and additional relay the the power line from the to the Hi Fi amp is used to switch the relay which is hooked up to Power some how (power directly from the battery) Usually the better amps have some kind of turn on signal for the next amp in line. There are a bunch of DIY's on how to add a relay on ytube. Last edited by ctuna; 06-01-2020 at 06:12 PM.. |
06-03-2020, 03:22 PM | #6 |
11
Rep 54
Thanks again Ctuna.
No issues with sorting a relay. In fact today I have just wired one to turn on my fans and a 12v/5V regulator (for a bluetooth to SPDIF reciever in my boot), triggered by my Helix P6 remote output. I'm led to believe that the HU has a black wire for antenna power that can be used to power on the amps. However, I've given up on the idea of recoding to HiFi. Benefits do not outweigh the negatives. I've now got a good REW sweep of the HU, and I think its enough for me to De_eq with my incoming Helix P6.....it has to be better than the poor job that the outgoing Audison did (it barely did anything to De-EQ, despite having de-eq functionality). Thanks again for your advise. When I've got a moment I'll post a screenshot of the factory EQ for others to see, as it might be usefull. |
06-03-2020, 07:42 PM | #8 |
1911
Rep 13,104
Yeah the helix should do it , it would use up some of the range
of the Helix though. I think 6spdcoupe normally does this he and he owns a stereo shop. |
06-08-2020, 09:48 AM | #9 |
9
Rep 88
I’m with ctuna here I used the cigarette lighter power from under the glove box for the remote source. I had to use a Icom to get the head unit to to hifi I tried every trick to recode it without it. Some say If you have a good kdcan cable it may work.
06-09-2020, 07:42 AM | #10 | |
379
Rep 2,365
Drives: 2007 E90 323i (Cdn)
Found a thread on this forum that pointed me to a wire to tap for remote to work on key insert (nonCA) rather than car start. Cheers!
06-14-2020, 03:24 AM | #11 |
11
Rep 54
Incidentally, I've been able to get a reasonably flat input EQ using the Helix P6 Mk2 DSP input EQ for my base stereo using high level. The OEM EQ was boosted massivley from about 1.5kHz (2 humps up to about 10dB), had a biggish hump at around 600Hz, an 8dB hump at about 70Hz, and what was most puzzling was two huge (up to 12dB) cuts with a very high Q at about 40Hz and 180Hz. The P6 has only 5 bands of EQ on the input, but by using the shelf filters I've got it to be within +/- 1.5dB, apart from one of the dips at 40Hz. I was wondering if the dips might be an applied all pass filter as the 180Hz corresponds to the handover point between the underseat midd bass and the door speakers, so applied an inverted all pass filter but that didn't do anything, so for some reason BMW have just added a couple of huge dips (unless of course my ADC just simply has two dead spots). Regardless, its now close enough for me to start EQing the outputs, and its much closer to flat than my old Audison DSP auto EQ was able to do.
fwiw, my HU (x1 E84 2014 CIC Nav) doesn't change either the shape nor magnitude of the OEM EQ with volume. |
Ali-E90378.50 |
06-14-2020, 10:58 AM | #12 |
1911
Rep 13,104
In my Hi Fi system the underseat where working but there contribution
was almost non existent till I put some power to them then I could get some muddy bass out of them . When I changed them out to Jehnerts is when my lower end and mid range really came alive. I can only imagine the base system is way worse . Plus they had to split Head Unit power between the underseats and doors maybe they put that dip in there because of power limitations. https://www.e90post.com/forums/showt...ighlight=graph |
06-18-2020, 03:01 AM | #13 |
11
Rep 54
OK, so this is the un-eq'd electrical FR plot of front left (right is the same) speaker for my 2014 CIC I-drive Nav X1 E84 base stereo.
This is the EQ I applied using the Helix Input EQ: Which resulted in this: Not ideal, but with only 5 channels of EQ, getting nearly everything to +/- 1dB is good enough to take forward to accoustical output EQ. That said I'd welcome any advice to improve it further, eg I suspect I could tweak the high shelf filter frequency and Q to to smooth out the 750 - 5kHz range, but not sure what to do as my trials introduced other issues. |
06-18-2020, 03:15 AM | #14 |
11
Rep 54
Fwiw my hardware is as follows:
Helix P6 DSP 6x100W powering tweets, mids, and mid bass (underseats), fed by High Level Helix Director Focal Solid 1 amp powering Sub Tweeters: Vifa OT 19 on axis in sail panels, but also thinking of replacing these Mids: Audifrog GB40 (very noticeable step up from teh L7s/HK I had in there before) Mid Bass: Focal IFBMWSubV2. I know they don't go as low as others, but they have very good clarity and as I have a sub in the boot they are a midbass, not a sub. Sub: Focal 27WX Utopia in a custom pod in the rear boot side panel (to be modified by increasing size and giving it a milkshake coating inside) Will be tuned using REW and a Dayton UMM-6 Mic. The director allows for up to 20 sound settings in the P6, so I'll be trying Audiofrog, Half Whiteledge and Jazzi house curves. |
Tags |
base, hifi, recode |
