Qustion about speaker ohm's
05-20-2020, 12:28 AM | #1 |
347
Rep 2,281
My car has a 4ohm sub. logic 7 I believe. Can I install a 2ohm sub? will it damage the amp.? or sound bad? Can I add a resister to it?
I am almost getting it for free that's why I'm asking. Thanks. |
05-20-2020, 09:00 AM | #2 |
19
Rep 68
A 2 Ohm sub will be louder than a 4 Ohm sub, and will demand more power due to a lower resistance. If your replacing the stock under-seat sub using the integrated amp I wouldn't recommend it.
05-20-2020, 11:57 AM | #3 | |
372
Rep 531
Drives: 2007 E70 4.8i, 2008 E90 335i
In general you can always put in higher resistance speakers on an amplifier but lower can create problems. 2 ohm speakers draw twice the current so therefore twice the power at a given voltage so the amp has to be able to handle it. I am how the BMW amplifier is designed. The sensitivity (efficiency) of the speaker also plays an equal role. If you have an 91db sensitivity 4 ohm speaker it will be roughly the same SPL (sound pressure level) which is essentially volume that you would get with a 2Ohm 88db speaker. Power and SPL doubles every 3db. Car speakers are usually lower ohm (impedence) than home audio speakers because cars run at 12-14volts which really limits the amplifiers. Home amplifiers usually run 30-70V at the amplifier rails depending on the power requirements. -Rich
2007 E70 X5 4.8i with 10" android screen Running 265/60/18 AT34s All Terrains (Mainly for road trips)
2008 E90 335i with 10" android screen, 7" intercooler, inlets, Dinan intake, JB4 BEF, E85 conversion, Mfactory LSD, M3 suspension, EDC shocks with custom controller. |
05-20-2020, 02:48 PM | #4 |
1911
Rep 13,104
There was a thread in here someplace where people substituted
other stuff for the underseats, it was a long way back. The following thread has some info about the output chips https://www.e90post.com/forums/showthread.php?t=1144129 https://www.e90post.com/forums/attac...2&d=1435788287 pretty underwhelming at BMW specs the power a 10 percent distortion. |
05-20-2020, 03:51 PM | #5 | |
1903
Rep 6,968
Drives: 2007 Black/Black 335i e90
A lot of amps will list 2 RMS values Like : 250 RMS @ 2ohm 150 RMS @ 4ohm So, for example you have underneath subs that that have a 150 RMS @ 2ohm value with a peak of 500watts You would want to have the amp be 150 RMS @ 2ohm. The stock logic 7 amp might be around 60 watts per channel. The logic 7 subs are 4ohm. I don't know the RMS of the logic 7 amp. |
