BMW X5
      05-15-2020, 02:01 PM   #1
rothwem
Drives: 2009 BMW 328i Wagon
2009 BMW 328i  [0.00]
OEM Trailer Hitch Retrofit?
My sister in law just got a new leftover 2019 X5. She's not going to be towing with it at all, so she didn't pick one out with the towing package. She does want to put a hitch for her bike rack on it though, but she's (rightfully, IMO) worried that with all of the electronics in the rear tailgate/bumper area, an aftermarket hitch would mess with her warranty. She wants OEM only, installed by a dealer. However, her local dealer says that the retrofit doesn't exist? Is this true?
I don't have any experience with the G05s, just the E-series vehicles, and I know that the dealer will do a retrofit of an E70 or E83 with no issues. Is there something weird on the G05s that would prevent it from having the hitch installed? I see P/N 51126889278 on getbmwparts.com for the US version of the trailer hitch.
      05-16-2020, 06:42 AM   #2
James_G0540i
Australia
446
Drives: 2021 X5 G05 40i M Sport
There is an after-factory OEM factory hitch option, have a look at the pics below.
I actually think its better than the factory hitch because its hidden and removable when not in use, which keeps aesthetic look of the rear clean.
The only downside is it's not rated to tow 3500kgs, only 2700kgs - but more than enough for my needs.
Best to get the dealer to do it, because it needs to be coded into the vehicles ECUs, which also enables a "trailer mode" which disables the rear distance sensors and co-ordinates the trailer with the cars safety systems.
      05-16-2020, 01:09 PM   #3
sanchezldo
sanchezldo's Avatar
Drives: 2020 X5 M50i
Stealth Hitches
I strongly recommend Stealth Hitches. Had one on my X4 M40i and just installed one on my X5 M50i. You can buy a kit with a receiver, a ball, or both. Very easy to install and rated to 8,000 for towing.
JS
Appreciate 3
      05-16-2020, 01:43 PM   #4
LexxM3
LexxM3's Avatar
1699
Drives: E46M3, G05X5
2019 X5  [0.00]
Reminder on this thread that factory BMW hitch in US, Canada, and maybe some other markets is completely different than rest of the world. The OP is in US and I suspect the request assumes a US version, which is a female receiver.
Interestingly, I believe that's the first time I am seeing the after-factory OEM version in the style James_G0530d shows. No idea if that will fit a US car, but I doubt it.
G05 X5 x40i (04/2019 mfg, Canada) on S18A-19-11-540
      05-16-2020, 05:32 PM   #5
rebekahb
3133
Can you see yours when not in use? That was my one complaint with the X5 was there was no plate to cover the area when the hitch was removed. My prior vehicle had all the same sensors but you could pull the hitch out & put the cover on.
We don't tow in my vehicle often but it's nice not to take my husbands F-250 on a 4 hour road trip to tow the fishing boat.
      05-16-2020, 09:01 PM   #6
James_G0540i
Australia
446
The tow bar fitted to my car also has a female receiver under the rear bumper.
The installation is quite involved, and involves removing the rear bumper and replacing the crash-bar with a version that has the towbar receiver.
I've attached the installation instructions - not that I would attempt to do it myself - I recommend getting the dealer to do it, and code it properly into the ECU so it integrates with all the cars safety systems.
The towbar system itself is made by Westfalia (made in Germany) - and BMW supplies and fits this as their OEM, at least here in Australia.
I'm curious as to why you say this wouldn't fit the U.S cars?
..I mean our cars come off the same production line from Spartanburg SC?
File Type: pdf X5_towbar_Installation_Guide_303484691102-303485 001.pdf (13.17 MB, 1464 views)
      05-17-2020, 05:43 AM   #7
rothwem
She's really worried about her warranty, that's why she wants an OEM option, installed by the dealer. She got 10,000 off on the car too, so I guess she doesn't feel too bad paying $1000 to have a hitch installed.
She also needs the 2" receiver type, not the ball. This is really only going to be used with a bike rack.
      05-17-2020, 04:07 PM   #8
LexxM3
LexxM3's Avatar
1699
2019 X5  [0.00]
I am glad you stated that you attached the instructions as the stupid Bimmerpost App doesn't even give you a hint that a post has non-image attachments. That should be SOP: if you attach anything other than pictures, state that you've attached something (better SOP is for the Bimmerpost App be fixed in the next decade or two).
Looking at instructions, it actually doesn't look that bad at all as DYI (I was expecting welding, but it's just a bolt-on) — assuming of course that your specific car is set up for it. Sounds like AU models definitely are ready, but it is even odds in my mind whether US markets models are setup the same. I don't know either way, but BMW constantly does weird things with market models, and not just software, including mechanics. The fact that US and non-US have different stock hitches is a factor. Or there might be a sensor or a piece of trim that gets in the way. Or the sensor electronics get confused. No idea, but BMW often makes their own and others' lives complicated, that's the only reason for my caution statement.
It is also interesting that BMW Australia considers these OEM. It is definitely not made by BMW, however, but rather Westfalia Automotive and I also doubt that BMWNA is going to consider that "OEM" in US. Interestingly it is available in US regardless: https://etowbars.com/Towbars/BMW/X5/...-X5-G05-Towbar UPDATE: I take that back, it is NOT available for shipment to either US or Canada! Site says "no shipping options available" if you select either country and it's not on their list of shippable destinations.
Lastly, I don't see how a female receiver is setup on this from photos so far or instructions. Would you please post installed photos of yours in all positions for posterity.
      05-17-2020, 09:49 PM   #9
nosnoop
838
Drives: 5 Series
North American hitch receiver is quite different. It is a 2 inch square and orientated rearward horizontally. There is also a socket with the hitch package for electric connection.
They can have many variations of the car even in the same production line. For example, North American hitch package requires a different bumper. And there are many customized differences to cater to different regions/countries regulation requirement. So it is not a given than an Australia parts would fit a US car.
      06-04-2020, 11:19 PM   #10
JonnyCrash
Driver
163
Drives: VW GTI, BMW X5 40i M-Sport
Has anyone ever found out if the North American OEM hutch can be added as a retrofit? And if so, what parts are required for both the hitch and the bumper?
      06-05-2020, 08:33 PM   #11
Multimodal
2896
Drives: 2019 X5 50i, 2018 911 T
It is not yet available for retrofit.
Your best bet is Stealth Hitch. I've had them on my E70 and my G05 - they make a very high quality product.
By law in the U.S., your warranty cannot be invalidated due to an aftermarket part unless the manufacturer is able to show a direct link between the part and the failure. Check out https://en.wikipedia.org/wiki/Magnus...s_Warranty_Act
Current garage: 2023 Rivian R1S Adventure Forest Green/Ocean Coast, 2018 Porsche 911 T Carrara White Metallic/Black, 2019 Ram 2500 Big Horn Diamond Black/Diesel Gray
Archived: 2019 BMW X5 50i M Sport Mineral White/Full Black,2019 Ford GT350 Ford Performance Blue/Dark Slate, 2012 BMW X5 50i Alpine White/Black, 2014 BMW 320i M Sport Melbourne Red/Black, 2009 BMW DINAN3 Alpine White/Black, 2008 BMW 335xi Alpine White/Black, 1998 BMW 328is Avus Blue/Tan
      06-06-2020, 08:30 AM   #12
denaliman
denaliman's Avatar
470
Drives: 2021 BMW X6M Competition
2013 X6M  [0.00]
Stealth hitch is probably the best option and for looks. However, I don’t think they have an OE BMW factory harness available. Stealth need to offer this option.
_____________________________________
2021 X6M Competition, 2021 Audi SQ5 Technik, 2013 Audi S4
      06-06-2020, 09:24 AM   #13
SWBOS
Drives: Soon - X5 40i
You're correct that Stealth don't have a BMW harness option available yet. I've been emailing back and forth with them for a little while and they're working on getting the parts needed so that they can get a package together.
I chose to go with a Stealth Rack install and am awaiting their Tow conversion kit with BMW harness (as they've had for previous X5 models). It's a little more pricey this way, but I'd like to keep with the BMW electronics.
No word on when the BMW harness will be available yet though I'm afraid.
      06-07-2020, 08:47 AM   #14
rothwem
So my sister in law just let me know she got the hitch installed at a different BMW dealership. I'm assuming it's OEM, or at least an OEM accessory? I don't think she got the wiring, she just wants it for a bike rack. So far she's thrilled.
No pics yet, but I am curious what they installed. I told her to keep her paperwork so that if she gets any grief later on, she can show them that it was installed by an authorized technician at a dealership.
      06-07-2020, 06:03 PM   #15
Mjbmw1
Mjbmw1's Avatar
Drives: X5 M50i
So I wasn't happy with the stock tow hitch either but it appears they now have a hide away oem US version.
Has anyone tried this yet?
      06-08-2020, 07:09 AM   #16
SWBOS
Originally Posted by Mjbmw1 View Post
So I wasn't happy with the stock tow hitch either but it appears they now have a hide away OEM US version.
Oh wow! Well that's a good find. It does look like the goodeneck is fixed though and perhaps is for towing only. I don't see the typical 2" square hitch that I'd expect for a US vehicle.
Haven't checked yet, but I'm curious if those other part numbers for the controller etc, are different from previous ones I'd found (and sent to Steve @ Stealth)
      06-08-2020, 07:27 PM   #17
JonnyCrash
Driver
163
Very curious to see the actual product and to know if it interfaces properly with the idrive!
      06-10-2020, 07:42 PM   #18
Multimodal
2896
That's the hitch for non-US markets. I've never seen that installed on a US vehicle. I am not sure I'd want that on my vehicle unless I could change out the ball size (different trailers have different size ball couplers).
What I'm really interested in is that BMW San Antonio somehow got the wiring harness (61-12-9-834-453) which multiple dealers have told me is not yet available / on national backorder. I may have to give them a call!
      06-12-2020, 11:18 AM   #19
Mjbmw1
Mjbmw1's Avatar
Drives: X5 M50i
No that hitch is US market it says it when you look up part numbers. Also in the US you cannot lookup European part numbers and vice versa. I am in Germany and they cannot look at any US parts or Order. I have tried 10 dealers.
I also have a quote from Dallas
      06-12-2020, 12:38 PM   #20
JonnyCrash
Driver
163
Ok, someone order one and then we’ll know for sure. Nobody up North I’ve spoken to can find anything available.
      06-25-2020, 09:08 AM   #21
Shawzy44
Shawzy44's Avatar
158
Drives: 2019 BMW X5 40iX
I am talking with BMW Toronto (Canada) on ordering the following for my 2019 X5 40iX.
https://www.realoem.com/bmw/enUS/sho...diagId=71_1114
Shawzy44
2023 BMW X3 M40i
2019 BMW X5 40iX
2019 BMW 440iX M Performance Cabriolet
      06-28-2020, 03:25 AM   #22
nosnoop
838
Drives: 5 Series
This looks like the factory hitch for 45e in Canada.
But do you only use it for towing?
I am not happy about the lack of 2" receiver as many of the hitch accessories I am using would no longer work like my bike carrier and cargo carrier.
xbimmers
